Are there any special steps or procedures I need to follow to connect my VeraLite to a new router. If I just plug the VeraLite into the new router will it work.
I don’t really want to change the router but I’m having some issues with the wireless signal.
Assuming that your Vera’s network settings are default, it may be necessary to power cycle the Vera after connecting to the new router. This is to force it to acquire a new address form the new router. Nothing else should be necessary unless the Vera is not using default network settings.
http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Lite&page=net_wifi
Ok, thanks. All the network settings are using the defaults.
