JohnRob: you asked if I could describe my heating system in another thread, but I’ll reply here since it seems more appropriate.
We live in Norway and the winter temperature here can get down to -25C and the summer temperature can climb well above +30C if we are lucky. Our house is also a bit special. Its a old horse stable built around 1880 which has been renovated into a house. Its not the most energy efficient house. I guess we traded that for a bit of charm. With this in mind its been very important for us to have a heating which does not completely shut down during winter.
Our heating is water based. We have a Mitsubishi Ecodan air to water system. It has heat pump outside and a storage module inside: Home - ECODAN
The Ecodan system is pretty much self contained. What it does is provide hot water. The inside unit has communication with the outside unit where it does measure the outside temperature and adjust the temperature on the water flowing in the pipes inside based on the outside temperature. There are some algorithms for this and these are adjusted to your house when its installed. The Ecodan is a kinda closed system and not connected or controlled by our z-wave network / Vera.
We have a certain temperature we want inside and we have adjusted our Ecodan to provide hot enough water to have this temperature inside. Then we use a set of thermostats and relays to keep the temperature at the level we want inside by turning heating units in each room on and off.
In the first floor everything is heated by floor heating (pipes in the floor). In the bedrooms, dining room and kitchen we have radiators. In the bathroom we have a water based towel rack which work as a radiator. We also have some big doors / windows in the first floor where each of them have a set of heat convectors.
All of these units (floor heating, radiators and convectors) have a actuator to control water going through the unit. An actuator is a electrical motor for opening and closing a valve. Our actuators are NC which stands for Normally Closed. That means that when they have no power the valve is closed and no water flows through. If one give it power the valve is open and water flows through. The actuators use 5-6 minutes to open and close so they regulate the water flow nicely.
We have actuators similar to those from Danfoss: Thermal actuators | Danfoss Global Product Store
To control the actuators I use the Secure SSR 303 relay:
http://www.vesternet.com/z-wave-horstmann-z-wave-controlled-boiler-receiver-hrt
This is actually just an on/off button. The only thing it does is turn the power to the actuators on and off.
Then I have the Secure SRT 321 thermostat which control the temperature in the rooms:
http://www.vesternet.com/z-wave-horstmann-wall-thermostat-with-lcd-display
This unit is paired with the appropriate SSR 303 relay(s). On the SRT one can adjust the temperature and it will control when the SSR 303 should turn the power on and off for the actuator(s).
My main reason for selecting these devices was that the thermostat has a manual control where one can adjust the temperature. Then I am not dependent on a controller to be able to adjust the temperature in a room. Then, the relay also have on / off buttons where I manually can turn heat on or off. This is important for me to have in case the thermostat fails to work at one point.
By having it like this I can manually control the temperature in each room and the devices talk to each other. There is no central unit controlling everything preventing me from having a single point of failure. I do not want my heating go down if a central unit fails. I am also able to manually turn heat on/off in each room if the thermostat breaks down. In other words; our heating control is very distributed.
My Vera controller does’nt really do much in our setup and I don’t want it to. The only thing I use the Vera to is to run a couple of scenes which will set the thermostats to a lower temperature level at night and a higher level at daytime plus lowering the overall temperature if I put the house in vacation mode.
I do also have a Secure SES 302 with a SES 002 pipe sensor:
http://www.vesternet.com/z-wave-secure-ses302-temperature-humidity-sensors
http://www.vesternet.com/z-wave-secure-pipe-tank-digital-temperature-sensor-1m-wire
This one is attached to the pipes which is the floor heating. Our floor heating has wooden parkett on top and the heat in the floor should not go above a certain temperature. The wooden floor will be damaged if it does. These devices then measure the temperature of the pipes and turns the water flow on/off to protect the parkett if it get too hot.
One thing I have not addressed yet (my next task) is to control the fans on the heat convector. A heat convector is just a radiator with a fan blowing air through the radiator. At the moment I am just controlling the radiator as described above. I am not 100% sure how to control the fans but I have been advised not to have them run constantly when the heating is on. They should run in bursts / small periods of time.
I am thinking of using a Secure SIR 321 to control the fans:
http://www.vesternet.com/z-wave-secure-wall-switch
The SIR 321 will give me a manual unit to run the fans for a certain amount of time. Which is what I want.
I am not sure if this helps you but this is at least our setup and it works pretty well.
