Question about this forum
I have a question. I’ve been a Vera owner for over 2 years and I’ve enjoyed this forum as a lurker for a long time. A few days ago I tried to make my first post regarding Blue Iris software in this directory and my post was noted as ‘Awaiting approval’. When I returned to check on the status it no longer appeared and I received no message that it was deleted or otherwise. Would someone help me understand what happened? Thanks.
Would anyone be able to tell me if Blue Iris software allows for digital panning and zooming around the displayed camera field if a wide enough field of vision is displayed? A sort of simulated PTZ? Thanks
Is this question not better asked on the “cam-it” forum, specifically for Blue iris?
Cor
All the web commands look like they are documented in Blue Iris Help
open Blue Iris, then open Help
then under “The Web Server”
look for
/cam/{cam-short-name}?pos=x
You may want to also set authentication to “Non-LAN only” under Options(the screwdriver\wrench icon) then webserver tab, this made testing easier.
Jeff
