Hi at all, I install a new dimable light with driver 0-10V command. I buy the Qubino ZMNHVD1 it work but whent you make light off the light stay a litle on and i have 0.2V on the dimable command.
I try to make a Fibaro RGBW, it work perfectly but the statu is reverse (when light is On statu is Off …) Do you know if it’s possible to revers this information into vera? I connect also the + off command to W and + and - to 12v power services of driver. The - of command is common to the - of power. I work in reverse.
