You first have to go to the pain of truly resetting the device. Either attach it to 24 volts so you can click the button, or attach a switch so you can do the toggle exclude/reset. I truly do not understand why you cannot reset/exclude the qubino using the build in switch on 230 volts. It makes it a pain.
Once you relay got it reset, follow the standard instructions to include, but be sure to have it within one meter of the Vera. that is the scenario I managed to get it working. For some reason with 7.30 you have to include any device that supports secure classes within that one meter range. Before only locks required that. So yeah, it is a 7.30 thing as far as i can tell.
Good luck.
