Some people use this module? Which Module are used to pair in UI?
I used the “fibaro shutter” module for pairing but I don’t know if it is correct…
Model number is:
QUBINO ZMNHCA2 - H1S2P1
At this time the device works with VERA but not with the original remote control, there are some parameters to be set for I1 and I2?
When I use the original remote I can hear the relay but the blinds do not move…
vera lite with vera ui 7
thks for your help!
Mount
