Hello community,
I have a little problem (I hope it’s little)
I use that for my bedroom, Qubino
Flush-mounted dimmer 0-10V, for dimming the bedroom lighting.
Because I have no way of connecting the dimmer to several buttons (for dimming from the bed), I bought the ZRC-90 (Scene Master) with which I can switch the light on and off perfectly via Reactor, but unfortunately not dim it.
The main button is built into the flush-mounted box by the door with which I can switch on / off and dim.
I’m not getting anywhere with StepUp and StepDown.
My plan is with a dim + button and dim- with another button.
Is there a solution for this?
Greetings Burkhard
