Hi
I’m looking at ways to better troubleshoot the luup/lua code I’m learning to write, and within many threads on this forum I can see ‘print’ is being used to check, however i do not seem to be able to use that when using the lua uPNP log file to check for errors - Print commands do not seem to show up …
So with that in mind, can you simply replace Print command with luup.log for everything ? Are there things it can’t do that luup.log can’t do ?
