I’ve got an issue I am not sure about. The appliance switch (Homepro ZRP100) shows up but Vera says, “Unable to get any information on node”. If I click on the On button in UI4, Vera will send the code and the switch will turn on but Vera will report back, “Transmit failed with code: 1” (BTW, if I put the ZRP100 in a plug that sits next to the Vera then everything works fine so I’d say the switch itself is in good working order. Also, I included the switch while it was sitting in it’s final location and paired it by moving the Vera right next to it and following the standard procedure to add a device.
Any ideas what I should do here? Is it that the ZRP100 is on the ragged edge of being too far away from the Vera?
I did a repair on just the node of the switch and get the following report…with a Heal Successful response from Vera but the UI4 still flags the device red and shows errors.
Thanks,
Chad
[code]10-11-30 21:38:50 report for HealNetwork. Successful: Y Updated net: N Job ID: job#17 :heal network (0x0x71dcb0) P:71 S:5
=======NEIGHBOR NODE UPDATES=======
Node 9 Device 11 Xmas Tree Switch neighbor nodes updated 0 times (incomplete 1 in a row 0), woke up 0 times configured: NO
=======STRESS TEST RESULT=======
Test: NOP Sent 2 test frames and 0 succeeded (0%) with average of 0.000000 seconds and maximum of 0.000000 seconds
Test: Basic_Get Sent 2 test frames and 0 succeeded (0%) with average of 0.000000 seconds and maximum of 0.000000 seconds
=======NEIGHBOR NODE RESULT=======
Node 9 Device 11 Xmas Tree Switch took 0.156554000 seconds to report neighbors: 1,
Inversely:
Node 9 Device 11 Xmas Tree Switch is seen by: 1,
=======DETAILED LOG=======
–Stage #1 started: 10-11-30 21:38:50 completed: 10-11-30 21:38:50 successful: N
—10-11-30 21:38:28 Job unknown
–Stage #2 started: 10-11-30 21:38:28 completed: 10-11-30 21:38:50 successful: Y
—10-11-30 21:38:28 Pass 0/5 Updating neighbors for node 9
—10-11-30 21:38:37 Job job#18 :heal_neighbor_node 9 (0x0x71f290) P:70 S:4 was Successful
—10-11-30 21:38:37 Neighbor Update Done
–Stage #3 started: 10-11-30 21:38:37 completed: 10-11-30 21:38:50 successful: Y
—10-11-30 21:38:37 Configure node 9
—10-11-30 21:38:42 Job job#19 :conf_jh#9 (0x0x721a30) P:70 S:3 was Aborted: Unable to get any information on node
—10-11-30 21:38:42 Configure Done
–Stage #4 started: 10-11-30 21:38:50 completed: 10-11-30 21:38:50 successful: Y
—10-11-30 21:38:42 Battery devices awoke
–Stage #5 started: 10-11-30 21:38:42 completed: 10-11-30 21:38:50 successful: Y
—10-11-30 21:38:42 Routing update node 9
—10-11-30 21:38:42 Job job#21 :heal_routing_node 9 (0x0x726628) P:70 S:4 was Successful
—10-11-30 21:38:42 Routing update done
–Stage #6 started: 10-11-30 21:38:42 completed: 10-11-30 21:38:50 successful: Y
—10-11-30 21:38:50 Stress test Done
[/code]
