Hi Rigpapa,
I’m trying to get the pushover notifications to work. Do I need to create an application token in pushover or can I use the user key?
I’ve tried both, but can’t get it to work yet. What do I put in the “PushoverUser” variable?
I do not see any errors in the logging.
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.9develop-20295.1440 config 20263 cdata 20045 ui 20190 pluginDevice 77 LuaXP not loaded
System: openLuup version 200522 on Linux 3858c2f27237 4.15.0-118-generic #119-Ubuntu SMP Tue Sep 8 12:30:01 UTC 2020 x86_64 GNU/Linux; in ./; loadtime 1461088957/1603963967; systemReady 1603963972; ALTUI v2.50
Env: Lua 5.1; JSON dkjson 2.5; UnsafeLua=nil/2
Local time: 2020-10-29T10:41:19+0100; DST=0; Zwaag, Europe Nederland; formats %d/%m/%Y %H:%M:%S
House mode: plugin 1; system 1; tracking off
Sun data: {}
Geofence: not running
RS: 1603909957,1603910008,1603914890,1603956845,1603956950,1603957159,1603957376,1603959119,1603961034,1603963967
NS: 1603957080:D,1603957201:U,1603957320:D,1603957380:U,1603957500:D,1603959120:U,1603959240:D,1603961040:U,1603961160:D,1603962122:U
Reactor Hank controller (#78)
Version 19082.153 10/29/20 10:08:30
Message/status: Not tripped
Condition group "Controller" (OR) false as of 10:40:56 <root>
|-F-group "Button 1 push" (AND) false as of 19:37:40 <grplbj35f0>
| &-F-service Four Button Scene (10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene = 1 [13 at 19:37:40; F/F as of 19:37:40/19:37:40] <condld4jqgp>
|-F-group "Button 1 release" (AND) false as of 19:37:40 <grplbu4b94>
| &-F-service Four Button Scene (10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene = 11 [13 at 19:37:40; F/F as of 19:37:40/19:37:40] <condldeckvw>
|-F-group "Button 2 push" (AND) false as of 19:37:40 <grpldjq10b>
| &-F-service Four Button Scene (10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene = 3 [13 at 19:37:40; F/F as of 19:37:40/19:37:40] <condldjq39z>
|-F-group "Button 2 release" (AND) false as of 19:37:40 <grpwlc9n3z>
| &-F-service Four Button Scene (10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene = 12 [13 at 19:37:40; F/F as of 19:37:40/19:37:40] <condwlc9pee>
|-F-group "Rookmelder armed and open" (AND) false as of 10:40:56 <grpyaqtnn7>
| &-F-service DWS02 Rookmelder 1 (10628) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 1 [1 => 0 at 10:40:56; F/F as of 10:40:56/10:40:56] <condyaqtp2o>
Activity grpldjq10b.true
Device Afzuiging (10483) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="1" )
Activity grplbu4b94.true
Run scene 30 User modes - Button Night (via luup)
Activity grpwlc9n3z.true
Device Afzuiging (10483) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="0" )
Device Afzuiging (10483) action urn:upnp-org:serviceId:Dimming1/SetLoadLevelTarget( newLoadlevelTarget="0" )
Activity grpyaqtnn7.true
Notify method PO nid 1: message "Er is rook in huis"; index="1"; priority="1"; title="Roolmelder alert"
Activity grplbj35f0.true
Run scene 29 User modes - Button Home (via luup)
Events
2020-10-29 10:32:47.030: Reactor startup (Luup reload)
2020-10-29 10:32:47.030: Starting (Luup Startup/Reload)
2020-10-29 10:32:48.056: Sensor update starting
2020-10-29 10:32:48.058: Sensor update completed; 0.002s
2020-10-29 10:34:23.996: Device Four Button Scene (#10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene changed from "13" to "13"
2020-10-29 10:34:23.996: Sensor update starting
2020-10-29 10:34:23.996: Sensor update completed; 0.001s
2020-10-29 10:36:05.886: Device Four Button Scene (#10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene changed from "13" to "13"
2020-10-29 10:36:05.887: Sensor update starting
2020-10-29 10:36:05.888: Sensor update completed; 0.001s
2020-10-29 10:37:48.252: Device Four Button Scene (#10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene changed from "13" to "13"
2020-10-29 10:37:48.252: Sensor update starting
2020-10-29 10:37:48.253: Sensor update completed; 0.001s
2020-10-29 10:39:30.191: Device Four Button Scene (#10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene changed from "13" to "13"
2020-10-29 10:39:30.191: Sensor update starting
2020-10-29 10:39:30.192: Sensor update completed; 0.001s
2020-10-29 10:40:46.237: Device DWS02 Rookmelder 1 (#10628) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped changed from "0" to "1"
2020-10-29 10:40:46.237: Sensor update starting
2020-10-29 10:40:46.237: Condition condyaqtp2o test state changed from false to true
2020-10-29 10:40:46.237: Condition condyaqtp2o evaluation state changed from false to true
2020-10-29 10:40:46.237: Group Rookmelder armed and open test state changed from false to true
2020-10-29 10:40:46.237: Group Rookmelder armed and open evaluation state changed from false to true
2020-10-29 10:40:46.237: Group Controller test state changed from false to true
2020-10-29 10:40:46.237: Group Controller evaluation state changed from false to true
2020-10-29 10:40:46.238: Preparing Rookmelder armed and open.true (grpyaqtnn7.true) activity
2020-10-29 10:40:46.238: Launching scene/activity grpyaqtnn7.true
2020-10-29 10:40:46.238: Starting "grpyaqtnn7.true" group 1 at step 1
2020-10-29 10:40:47.056: Activity "grpyaqtnn7.true" finished in 0.81800007820129s
2020-10-29 10:40:47.056: Stopping activity "grpyaqtnn7.true"
2020-10-29 10:40:47.056: Changing RS tripped state to true
2020-10-29 10:40:47.056: Sensor update completed; 0.820s
2020-10-29 10:40:56.371: Device DWS02 Rookmelder 1 (#10628) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped changed from "1" to "0"
2020-10-29 10:40:56.371: Sensor update starting
2020-10-29 10:40:56.371: Condition condyaqtp2o test state changed from true to false
2020-10-29 10:40:56.371: Condition condyaqtp2o evaluation state changed from true to false
2020-10-29 10:40:56.371: Group Rookmelder armed and open test state changed from true to false
2020-10-29 10:40:56.371: Group Rookmelder armed and open evaluation state changed from true to false
2020-10-29 10:40:56.371: Group Controller test state changed from true to false
2020-10-29 10:40:56.371: Group Controller evaluation state changed from true to false
2020-10-29 10:40:56.373: Changing RS tripped state to false
2020-10-29 10:40:56.373: Sensor update completed; 0.002s
2020-10-29 10:41:12.053: Device Four Button Scene (#10638) urn:micasaverde-com:serviceId:SceneController1/sl_CentralScene changed from "13" to "13"
2020-10-29 10:41:12.053: Sensor update starting
2020-10-29 10:41:12.053: Sensor update completed; 0.001s
Devices
ZWave (1) urn:schemas-micasaverde-com:device:ZWaveNetwork:1 (19/0); parent 6; plugin -; mfg Mi Casa Verde model GC100; dev D_ZWaveNetwork.xml impl X
Afzuiging (10483) urn:schemas-upnp-org:device:DimmableRGBLight:2 (2/4); parent 1; plugin -; mfg model ; dev D_DimmableRGBLight2.xml impl X
DWS02 Rookmelder 1 (10628) urn:schemas-micasaverde-com:device:DoorSensor:1 (4/1); parent 1; plugin -; mfg model ; dev D_DoorSensor1.xml impl X
Four Button Scene (10638) urn:schemas-micasaverde-com:device:SceneController:1 (14/0); parent 1; plugin -; mfg model ; dev D_SceneController1.xml impl X
Watches
Device #10638 Four Button Scene service urn:micasaverde-com:serviceId:SceneController1 variable sl_CentralScene
Device #78 Reactor Hank controller service urn:toggledbits-com:serviceId:ReactorSensor variable TestTime
Device #10628 DWS02 Rookmelder 1 service urn:micasaverde-com:serviceId:SecuritySensor1 variable Tripped
Device #78 Reactor Hank controller service urn:toggledbits-com:serviceId:ReactorSensor variable TestHouseMode
Device #78 Reactor Hank controller service urn:toggledbits-com:serviceId:ReactorSensor variable cdata
Special Configuration
UseReactorScenes = 1
Retrigger = 0
FailOnTrouble = 0
ContinuousTimer = 0
WatchResponseHoldOff = -1
Scenes
Scene #29 User modes - Button Home
Group 1
Device 2 ( openLuup) openLuup/SetHouseMode ( Mode="1" )
Scene #30 User modes - Button Night
Group 1
Device 2 ( openLuup) openLuup/SetHouseMode ( Mode="3" )
LuaLog
2020-10-29 10:40:41.075 luup.variable_set:: 10685.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1603964138 now: 1603964440 #hooks:0
2020-10-29 10:40:41.279 openLuup.server:: request completed (33796 bytes, 3 chunks, 4645 ms) tcp{client}: 0x55cfb10aa2e8
2020-10-29 10:40:41.393 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=963991697&Timeout=60&MinimumDelay=1500&_=1603963979159 HTTP/1.1 tcp{client}: 0x55cfb10aa2e8
2020-10-29 10:40:46.136 luup.variable_set:: 10594.urn:micasaverde-com:serviceId:HaDevice1.BatteryDate was: 1603964411 now: 1603964444 #hooks:0
2020-10-29 10:40:46.136 luup.variable_set:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.ArmedTripped was: 0 now: 1 #hooks:0
2020-10-29 10:40:46.136 luup.variable_set:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1603964388 now: 1603964444 #hooks:0
2020-10-29 10:40:46.136 luup.variable_set:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:1
2020-10-29 10:40:46.136 luup.variable_set:: 10685.urn:micasaverde-com:serviceId:EnergyMetering1.Volts was: 229.97 now: 228.25 #hooks:0
2020-10-29 10:40:46.236 luup.watch_callback:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped called [77]reactorWatch() function: 0x55cfafcc7830
2020-10-29 10:40:46.237 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpwlc9n3z":{"evaledge":{"f":1603910260},"stateedge":{"f":1603910260},"id":"grpwlc9n3z","evalstamp":1603910260,"l... now: {"grpwlc9n3z":{"evaledge":{"f":1603910260},"stateedge":{"f":1603910260},"id":"grpwlc9n3z","evalstamp":1603910260,"l... #hooks:0
2020-10-29 10:40:46.237 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.lastacc was: 1603964370 now: 1603964446 #hooks:0
2020-10-29 10:40:46.237 luup.variable_set:: 77.urn:toggledbits-com:serviceId:Reactor.runscene was: {} now: {} #hooks:0
2020-10-29 10:40:46.237 luup.variable_set:: 77.urn:toggledbits-com:serviceId:Reactor.runscene was: {} now: {"ctx78.scgrpyaqtnn7.true":{"starttime":1603964446.238,"scene":"grpyaqtnn7.true","taskid":"ctx78.scgrpyaqtnn7.true"... #hooks:0
2020-10-29 10:40:46.237 luup_log:77: Reactor: "Reactor Hank controller" (#78) Performing "Notify" ("grpyaqtnn7.true" group 1 step 1)
2020-10-29 10:40:47.055 luup.variable_set:: 77.urn:toggledbits-com:serviceId:Reactor.runscene was: {"ctx78.scgrpyaqtnn7.true":{"starttime":1603964446.238,"scene":"grpyaqtnn7.true","taskid":"ctx78.scgrpyaqtnn7.true"... now: {"ctx78.scgrpyaqtnn7.true":{"starttime":1603964446.238,"scene":"grpyaqtnn7.true","taskid":"ctx78.scgrpyaqtnn7.true"... #hooks:0
2020-10-29 10:40:47.055 luup.variable_set:: 77.urn:toggledbits-com:serviceId:Reactor.runscene was: {"ctx78.scgrpyaqtnn7.true":{"starttime":1603964446.238,"scene":"grpyaqtnn7.true","taskid":"ctx78.scgrpyaqtnn7.true"... now: {} #hooks:0
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorGroup.GroupStatus_grpyaqtnn7 was: 0 now: 1 #hooks:0
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorGroup.GroupStatus_root was: 0 now: 1 #hooks:0
2020-10-29 10:40:47.056 luup_log:77: Reactor: "Reactor Hank controller" (#78) now "tripped"
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1603962484 now: 1603964447 #hooks:0
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.TripCount was: 511 now: 512 #hooks:0
2020-10-29 10:40:47.056 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.Message was: Not tripped now: Tripped #hooks:0
2020-10-29 10:40:47.164 openLuup.server:: request completed (53128 bytes, 4 chunks, 5770 ms) tcp{client}: 0x55cfb10aa2e8
2020-10-29 10:40:47.285 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=963991717&Timeout=60&MinimumDelay=1500&_=1603963979160 HTTP/1.1 tcp{client}: 0x55cfb10aa2e8
2020-10-29 10:40:56.269 luup.variable_set:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.ArmedTripped was: 1 now: 0 #hooks:0
2020-10-29 10:40:56.269 luup.variable_set:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1603964444 now: 1603964453 #hooks:0
2020-10-29 10:40:56.269 luup.variable_set:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:1
2020-10-29 10:40:56.370 luup.watch_callback:: 10628.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped called [77]reactorWatch() function: 0x55cfafcc7830
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"grpwlc9n3z":{"evaledge":{"f":1603910260},"stateedge":{"f":1603910260},"id":"grpwlc9n3z","evalstamp":1603910260,"l... now: {"grpwlc9n3z":{"statestamp":1603910260,"stateedge":{"f":1603910260},"id":"grpwlc9n3z","evalstamp":1603910260,"lastv... #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.Runtime was: 24546423 now: 24546433 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.lastacc was: 1603964446 now: 1603964456 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorGroup.GroupStatus_grpyaqtnn7 was: 1 now: 0 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorGroup.GroupStatus_root was: 1 now: 0 #hooks:0
2020-10-29 10:40:56.372 luup_log:77: Reactor: "Reactor Hank controller" (#78) now "untripped"
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1603964447 now: 1603964456 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 0 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:upnp-org:serviceId:SwitchPower1.Status was: 1 now: 0 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.LastReset was: 1603962484 now: 1603964456 #hooks:0
2020-10-29 10:40:56.372 luup.variable_set:: 78.urn:toggledbits-com:serviceId:ReactorSensor.Message was: Tripped now: Not tripped #hooks:0
2020-10-29 10:40:56.485 openLuup.server:: request completed (28997 bytes, 2 chunks, 9199 ms) tcp{client}: 0x55cfb10aa2e8
2020-10-29 10:40:56.607 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=963991732&Timeout=60&MinimumDelay=1500&_=1603963979161 HTTP/1.1 tcp{client}: 0x55cfb10aa2e8
2020-10-29 10:41:01.374 luup.variable_set:: 1057
