PushOver problems in 4.0
Hi:
I just upgraded to 4.0, but the PushOver notifications are not working if you use both a user-key and an app-key. Upon looking at the log, the form parameters seem to be incorrect, as it’s sending the app-key for both the “user” and “token”.
50 12/05/13 6:52:01.162 luup_log:3: VeraAlert:3:SendAlert:UsingDefaultRecipients:Pushover <0x2ae18000>
50 12/05/13 6:52:01.163 luup_log:3: VeraAlert:3:SendAlert:Msg:TestTest <0x2ae18000>
50 12/05/13 6:52:01.163 luup_log:3: VeraAlert:3:ExpandRecipients:Checking:Pushover <0x2ae18000>
50 12/05/13 6:52:01.164 luup_log:3: VeraAlert:3:ExpandRecipients:Adding Requested Profile <0x2ae18000>
50 12/05/13 6:52:01.164 luup_log:3: VeraAlert:3:SendAlert:Sending to:Pushover <0x2ae18000>
50 12/05/13 6:52:01.165 luup_log:3: VeraAlert:3:PushoverSend:Body:message=TestTest&token=XXXXX&user=XXXXX&priority=0&sound=bugle&title=Notification <0x2ae18000>
50 12/05/13 6:52:01.714 luup_log:3: VeraAlert:3:PushoverSend:Result:400Resp:{“user”:“invalid”,“errors”:[“user identifier is invalid”],“status”:0,“request”:“d967b8e7a1c366876f5ab6aecaf6210d”} <0x2ae18000>
You are right! My mistake. I will get a new release out today.
I did not notice it because I was using the Push plugin to test forwarding as well … I knew I was getting message to my iPad …
I’m having the same problem. Getting the error:
50	12/05/13 8:13:30.773	luup_log:67: VeraAlert:67:PushoverSend:Result:400Resp:{"user":"invalid","errors":["user identifier is invalid"],"status":0,"request":"ceec82ecd9cd216b2193152e793fd55d"} <0x2b5fd000>
After reading your post, I checked my log closer & see that the API token key is being sent for both the API token AND the user key.
50	12/05/13 8:13:30.377	luup_log:67: VeraAlert:67:PushoverSend:Body:message=Front%20Door%20Locked%20%7Btone%3A3%7D&token=aCCfNC[rest of API token]&user=aCCfN[rest of API token]&priority=0&sound=none <0x2b5fd000>
Update: Just saw Richard’s response. So . . . thanks Richard
