Its a little different with Ezlo. Create a meshbot on the Ezlogic.mios.com web site that is local on your controller. Set up the trigger conditions as you like then in the actions set up a notification. Pretty straightforward. It’s just easier to edit these “scenes” Meshbots from a browser than a phone screen.
Thank you for contacting Ezlo’s technical support.
In the process of upgrading the scene creation and automation capabilities in your Vera app, we’ve discovered that a few other users are having this same issue. I apologize for the disruption and am here to help you get this issue resolved.
The new scene-generating automation tool is called EZLogic, a powerful new feature — with a straightforward interface — that will allow you to quickly integrate and automate new devices as you add them to your current home automation system.
To access EZlogic go to ezlogic.mios.com (using your web browser)
Sign in with the same username and password you’ve been using to access your Ezlo controller in the Vera Mobile app
then add your Trigger: whatever you want it to be…
then add your Action. Action is how you will receive your notification, you can choose, email, Push etc and create your own messages, html etc etc.
Thanks, I was in the right area. I added it in at first but it did not work. I went back and added again, setting device, water leak == true and configured the push to the user.
It is now working. I dont know why now, but its working. Appreciate it.
I added an Ezlo plus controller to start configuring and getting familiar with and I disabled notifications on it through the MiOS app and I am no longer receiving notifications or emails from my Vera controller. Some of these notifications are sent from lua scripts. If I enable notifications in the MiOS app I get duplicated notifications from Vera and MiOS, e-mails aren’t duplicated. These are two totally separate systems why is one affecting the other?
Update also getting multiple push notifications but only one e-mail.
Could someone from Ezlo elaborate on what is currently going on with notifications with Vera controllers.
In particular getting duplicates (got 44 last night) and now it says ‘Unit Notification’ in the e-mail subject.
If there’s work being performed it would be nice if the end users were notified beforehand.
On 4/25/25 my Ezlo unit starting sending push notifications and emails every time a door or lock changed state. I’ve never had this notification setting on in the app or web portal. I checked and it was still off. Notifications kept coming. I stopped the apps from being able to send notifications. Emails kept coming. I turned off all notifications in the app. Emails kept coming. I changed my user account to have the emails go to an unmonitored email address, didn’t work, they keep coming to my original email.
Obviously, something has happened on the Ezlo end without warning, but this is insane. I’m getting spammed by my own device without anyway, short of unplugging it, to stop the notifications. Any suggestions?
Unfortunately, it appears that this issue is related to our server infrastructure. Please rest assured that our development team is actively investigating the root cause. We truly appreciate your patience and understanding, and we will keep you promptly informed of any updates.
