Is it possible to send to a push notification to the Vera Mobile app (iOS) using luup?
I have a scheduled scene, and would like to be notified when a particular condition is met.
I realise that I could use Vera Alerts and Prowl / Pushover etc but would like to keep everything in the Vera Mobile app is possible.
If you go under User and Accounts ->User Info select Send me Push notifications. You’ll get push notifications on your phone though the Vera Mobile App. Now I need to figure out how to customize the message.
Thanks, but my specific question was how to generate push notifications for Vera Mobile with luup code?
I can’t leave it to the scene to notify me as it runs every five minutes. However, the condition to warm the loft to prevent pipes / tanks freezing only occurs when the loft temperature drops to 3C or below.
I realise that probably not many people use the Vera Mobile app but can’t believe there’s no api for sending push notifications.
Id also like to figure this one out so I can eliminate the emails fwd to txt messages I have set up. AT&T cycles through 100 different numbers when you email to text. This fills up your iMessage on phone and other iCloud connected devices.
Also One device sends cryptic code messages I would like to customize
