Proxy Error
When i try to connect to my vera from my cell phone or remote computer, i get this message.
"The proxy server received an invalid response from an upstream server.
"the proxy server could not handle the request GET https://xxx.xxx.xxx.xxx/cmh/.
"Reason: Error reading from remote server
"Apache/2.061(Unix) server at xxx.xxx.xxx.xxx. port 3128
I dont know if its the vera or the sattelite that is having problem.
Is the Smartphone Web Interface plugin installed? Can you please try from your PC to open http://findvera.com/mobile and see if you get the same error. If you do, please send us a trouble report from Advanced > Tech Support on your Vera.
