to contribute something useful, here is what i have done in the gardening matter:
Parts used:
[ul][li]2 x 1/4" Valves US $6.29 from Alibaba (seller sucks but the product is okay)[/li]
[li]1 x Raspberry PI B US $43 from element14[/li]
[li]1 x PI-Face Board US $44 from element14[/li]
[li]1 x PC Power supply[/li]
[li]20 Meters Telephone cable[/li]
[li]2 Liters of Coffee/Red-Bull[/li][/ul]
well i have to admit, it is alittle bit more than 20Bucks, but the Raspberry does mainly other jobs like holding my mysql datamine database and xbmc data, webserver and hosts another 6 Door sensors (they also show on the vera) so the more expense are somewhat compensated.
basically a Aurdino for 10bucks and a relay can do just the same. and we back to 20 Bucks ![]()
the RPI runns a small python script … that listens on the inputs and doestrigger the veras switches accordingly in realtime.
and it listens also to http commands to trigger the outputs.
so on the Vera … we have Virtual switches using
- D_BinaryLight1.xml or D_Relay1.xml (as you prefer)
- I_VirtualSwitch.xml
and a scene with no action.
in the scene have triggers set up for the virtual switch turned OFF and ON
and in the luup section simply have the http call to the PI to actually do what the switch should
like:
luup.inet.wget('http://172.16.67.21:8000/?output1=0', 5)
all the rest is very straight forward (i guess)
i just have not yet managed to get the pipes dry … they tend to leak (used alot of rubber tape but there is still getting some drops of water out … (i’m just not good in this things) ![]()
oh as for the sprinklers itself. i simply connected a plastic garden hose (20 meters)
used a lighter and a paperclip … (make it hot with the lighter) and punch a few holes here and there …
not perfect, but works and its dirt cheap ![]()
