Can you describe the “default remote”? Are you referring to the remote opener in the car, or are you referring to another wall mounted push button switch?
Assuming that you wired your ZFM-80 correctly, as per the diagram, I would suppose that you have not configured the ZMF-80 for an external push button.
In the Vera UI5 click Devices → ZMF-80 Wrench → Device Options → Add Configuration Settings.
In the variable field enter 1.
In the data size drop down choose 1 byte hex.
In the desired value field enter 1.
Also, as per the instructions, consider a fail safe time out configuration.
In the variable field enter 2.
In the variable field enter 3.
In the variable field enter 4.
In the desired value field enter 0.
Then save your changes and the push button should work.[/quote]
Zwaver wanted to let you know that this is working perfectly fine now. The default push button plus the remotes and above functioning zwave garage door opener ![]()
Cannot thank you enough.
