Hello,
I am interested in changing the default configuration of the LED indicator (Night Light) on the Evolve LRM-AS switch. The instructions state:
By default, the LED on the LRM-AS will turn OFF when the load attached is turned ON. To make the LED turn ON when the load attached is turned ON, set parameter 3 to a value of 0
[ul][li]Paramater No: 3[/li]
[li]Length: 1 Byte[/li]
[li]Valid Values = 0 or 1 (default 1)[/li][/ul]
I am using the latest UI from Vera and cannot find the location within the switch settings to make these changes. Can someone walk me though this?
Thanks,
