Problems with Panasonic BL-C230 pan controls
I partially have this camera working. I cannot get the streaming pan controls to work and the UI screen is broken by the pan control buttons.
when i click on them i get the error: “command failed: no implmentation”
see pic/screenshot here: http://tinyurl.com/3kw4ag6
thanks for any help
Did you add your xml file to the right place?
The impl_file area is located under the Advanced tab of that plugin.
