Problem with Remotec zxt-120
Hello!
In Device overview i see my zxt-120, but device not work and shown status Please wait! Getting the manufacturer
i`m try unpair and pair device again, but no luck
Device connect and diconnect every 2 seconds
[quote=“f1ip, post:1, topic:187311”]Hello!
Device connect and diconnect every 2 seconds[/quote]
What is the ZXT-120 version? maybe 1.5, 1.6H?
Hi.
how to check the remotec firmware version?
I got problem veraedge UI7 1.7.1320 suddenly “cannot detect device” even though few hours before I managed to make it works.
my remotec version : 6,3,42,1,3
I need to exclude and include it again but still few hours later, vera cannot detect device.
any advise?
thanks
[quote=“sapiloncat, post:3, topic:187311”]Hi.
any advise?
thanks[/quote]
you can check the label on the unit, saying 1.6H or 1.7A.
@ Vincent.
ups sorry, I miss it.
thnaks for pointing it out.
BTW any1 has problem on Remotec firmware 1.5 with Veraedge (latest firmware)? it always ‘can’t detect device’ after 1 day of successful operation.
firmware ver 1.6 shows no issues.
Same problem here.
I use 1.6H version with ver lite UI7.
Any solution for this issue?
I am having the exact same issue here ZXT-120 1.5 Vera lite ui 7 (latest firmware)
Works fine and suddenly no go, just getting “Can’t detect device”
Has anyone found a solution?
I use vera edge ui7 FW 1.7.1707 (latest) and zxt-120 1.5. It worka fine and no issue with can’t connect. No idea if using vera lite
Sent from my SM-G935F using Tapatalk
Back in 2014 I purchased two of ZXT-120 and had them both running for about one year on older, second gen model Vera. In about one year one of them started “falling off” the Vera - same “Can’t Detect Device”, but not persistently - the device would re-appear every now and then.
About six month ago, I upgraded to Vera Edge and re-added and re-programmed the one that kept disconnecting. Worked OK at first and in 2-3 month for both of ZXT-120 I would get first intermittently “Can’t Detect Device” and now persistently.
ZXT-120 fw v1.2A
My installation is remote. ZXT-120 is connected via USB adapter. The power goes off periodically and I suspect the device “forgets” the configuration.
I was hopping the issue is with ZXT, not VERA and I replaced the two ZXT-120 with new devices a month ago.
Worked until last night, when I saw again the dreaded “Can’t Detect Device” from one of them.
