Problem with NodOn buttons
Hi!
I newly bought a Vera Plus, a z-wave dimmer and a NodOn-buttons (Model: CWS-3-1-00).
I have successfully paired the Vera to both devices, and I have also full controll of the dimmer. From Veras interfaces I can controll the light in the room.
But I have not succeeded to get any reactions from the buttons on the NodOn device. I have tried to change the virtual lamp devices, or tried just to get a notification when the button is pressed. But nothing happends!
I have tried with lamp buttons number 0, 1, 2, 3 and 4.
I will attach a picture of my (at the moment two) scenes, and how the first scene looks like. In the scene list it says “last run” and some date, but that was when I manually pressed on the run button. Why does not this scene runs when I press the button?
Not a single answer? :frowning: Can someone at least please tell me if it looks that I have the configuration right?
It looks right
Hello
I have a problem
Attempt to read a cyclic temperature direcion KNX but I can not apply the value in mRemote … someone I can spend a small example?
