I am using luup.call_timer to run a routine daily. That worked just fine on UI6, but now I ported the same code to UI7 and the function is called for two or three days and then stops until I reload my Vera again. Quite annoying I can tell you.
local res = luup.call_timer("rbWinCov_AutoControlDaily", 2, "07:30:30", "1,2,3,4,5,6,7", "")
Anyone having a similar issue or sees what I could be doing wrong?
Cheers Rene
