hi
I reached a point of giving up and I hate that feeling .
I was wondering if you can help me wire this unit to my pool heater .
I enclosed a link to the manual .
not sure what I’m doing wrong ,I’m starting to think unit is damaged .
looked online not the only one having difficulty with the wiring this unit .
maybe you can post on your website after you help me .
I have attached 2 images of my last attempt ,still nothing .
I hear it click but no reading at the load output .
its a 240
I have red and black both reading 120 volts and white negative .
My pool heater is 230 volts 3 wire ,red ,black ,and white .
it has numbers 1 to 6 .
I put in my 2 lines in 1 and 2 (power supply ) and white in 3
my load line for pool heater 2 lines 1 in 4 and 6 (load line) and white in 5.
now I do hear it click ,the led light on ,but when I use my meter no volts reading at load lines .
try it other few ways . nothing . I really appreciate your help ,I even got a friend who is an electrician also could not figure it out ,the manual is no help .
I was going to get anther one for my pool pump ,I wasn’t sure if I can connect a relay
to shut off the pool heater first than pool pump to allow heater to cool down .
any advice is appreciated .
manual link below also attached images of my unit .work I done so you can see my wires .
http://waterheatertimer.org/pdf/Intermatic-CA3750-Manual.pdf
