Problem with Day and night app
Hello.
i want the vera to use the day and night plugin so when home mode goes on by geofence it first check if its day or night and then decides if lights should go on or wait until night…
I have installed the day and night app but gets this message when i try to configure it…
Error executing function daytime_Settings(): daytime_Settings is not a function. (In ‘daytime_Settings(220)’, ‘daytime_Settings’ is an instance of Object)
What can be wrong???
/ Mattias
Are you on UI5 or UI7 ?
Hello Ui7
Upgrade the plugin …
WHen it restarts … do a POWER reset (Unplug it).
Thanx! Now it works!!!
:+1::+1::+1:
Skickat fr?n min iPhone med Tapatalk
