Problem with association of TKBHOME switch
Just installed my new nice two button switches from TKBHOME with name TZ66-D.
I’ve able to add them into network and to assign to certain scenes.
It allows up to 4 groups association. Second button as I understood can be used only using association.
Here I’m totally failed. I did it using Vera2 Device Options tab. Such a way is working fine for my Duwi switches but not working for this new. Configuration going without error messages, I’ve tried to add group 1, 01, 001 in different notations - not working. What can be wrong?
Hi I also brought some of these devices as a trail. Single and Double + Plug, all added to Vera no problems, I can’t see the second paddle on the double. Both operate fine. Any ideas on how to program the second paddle?
Cheers
Seb
Unresolved, but just linking the other thread @axill had started on this.
I’ve got a solution from the TKBHOME - in my devices they missed capability 133.
Attached you will find an instruction how to configure association for devices with missed capability.
For me it is working.
It is also a good news that TKBHOME get certified with ID ZC08-11070004
I’ve just got a TKB TZ66D and can confirm it now shows up with 133 listed in capabilities. However I had assumed it would show up on the Vera dashboard as two appliance modules (although one would not have any actual load switch capability). I would prefer to manage the RHS switch like a virtual appliance module rather than specifying associations within it. Is it possible to use existing Luup files to build a virtual appliance module for the second switch to make configuration consistant?
