Problem Retrieving Live Variables from Devices
From luup code on a scene, I can never retieve live values from devices. Here is one example…it is using the awesome Nest Plugin checking if it is in Home or Away mode and returning a cancel or proceed route for the Scene. No matter what the Status of the Nest, the code returns the same value and in the Nest Device properties, I never see the variables updated, no matter what stat it is in. Is there anything wrong with it? I have tried so many samples posted online to do this or to read the simple Status of a Virtual Switch or Motion Sensor…no luck on anything.
Is there something wrong with this code, or is there something wrong with some other setting on my Vera3 unit?
local TSTAT = 70 – HOME/AWAY Thermostat Device
local TSTAT_SID = “urn:schemas-watou-com:device:NestStructure:1”
if luup.variable_get( TSTAT_SID, “Status”, TSTAT) == “1” then
return true
else
return false
You’ve fallen into the perennial newbie trap of using a service type for the string instead of a service ID.
Here’s some reading for you: site:forum.micasaverde.com vera service id hover - Google Search
futzle…you are awesome. I am an experienced programmer but yes a complete newbie at this. I am in my glory controlling my house…while simultaneously driving my wife crazy…what could be better than that! Thanks for the reading link.
Got it…I never noticed the hover over variable tool before. That’s convenient.
