Hi - I am relatively new to zwave world…but… I am think I am doing the right thing and it is not working!
We just finished building a new house and made every switch a z wave (evolve). They are all working great.
We also have a number of Cooper Scene Controllers which I cannot get to work correctly. (http://www.smarthome.com/21895WS/Cooper-Wiring-Devices-RFWC5WS-ASPIRE-RF-5-Button-Scene-Control-Keypad-White-Satin/p.aspx)
I think I have followed the instructions here: http://wiki.micasaverde.com/index.php/Cooper_Scene_Controller#Assigning_Scenes
The device is included. If I create a scene that turns on one light it seems to work correctly. If I then change the scene to turn on another light it - this light does not get turned on. if I reverse the order, I found that it seems that only the first light that I program works - the later lights do not.
I have tried two different scene controllers and got the same result.
I have Vera3. it does not seem to matter if I use the simple UI or UI_6.
Thanks for any help you can provide -
Tim.
