I have been scratching my head hard trying to figure out a way to Shift my existing VeraLt UI5 Primary controller so it becomes Secondary and Honeywell Tuxedo or VAM becomes the Primary.
Has anyone got lucky shifting Vera to become Secondary without loosing Devices ID’s and programming??
I have tried all the possible permutations I can think of to swap Primary role:
VAM/Tux enroled as Secondary then “Shift Secondary to Primary” from VAM/Tux menu + Vera “Controller Shift”…
VAM/Tux enroled as Secondary then “Add Device…” (to pull updates) from VAM/Tux menu + Vera “Controller Shift”…
VAM/Tux set as “Secondary” but not enroled then “Shift secondary to Primary” from VAM/Tux menu + Vera “Add Device”…
VAM/Tux set as “Secondary” but not enroled then “Shift secondary to Primary” from VAM/Tux menu + Vera “Controller Shift”…
VAM/Tux set as “Primary” but not enroled then Add controller from Vera…
Besides the Tux working as Secondary, the closest I got was both Vera and Tux as Secondary without any Primary controller left! : What am I missing to get Vera to Shift??
Plan B: the only other option I can think of is a drastic rebuild from scrath :
- Default VAM/Tux to Primary
- Manually Remove/Add all devices like new
- Add Vera as Secondary
Pb: all ZWave devices get a new HouseId+DevID screwing up existing programming on VAM and Vera.
FYI: to use the remote services of Honeywell TC2 (Alarmnet TotalConnect) on a Tuxedo or VAM, it has to be a PRIMARY controller. When Tuxedo is only a Secondary ZWave controller, it disables the “remote Scene” functionality that can be triggered by Vista PNL on “Fault” conditions.
Local scenes without said TC2 Remote Services are limited to 10 max… but with TC2 enabled ($12/Yr) you get a whole lot more scenes slots PLUS remote control from the TC2 Android/iPhone App. 8)
