prevent auto-creation of device
if i install one of my own plugins, a device is created, removing this will remove the plugin too.
is there a way to have it installed without the device is beeing created ?
To be able to run, a plugin must have a device instance. You could make it invisible, though. If you really don’t want a device created, you could place your code in Startup Lua rather than a plugin.
Yeah, well its not really a plugin,
I just want to deliver a set of xml files to vera to manually add them into existing devices.
Maybe not the right approach doing that.
