Hello,
First, thanks you for this interesting pluging, the arduinos are very instesting and have unlimited possibilities.
I am using an Arduino Sensor 1,3 Beta 2 and i have some problem with Pressure/Temperature/Weather forecast sensor (BMP085).
After a lots of tests, i find out that the problem is in the function int sample(float pressure), without run the function, all works well.
I have been little time with Arduino and i don’t know how to enter the debug mode.
Can you guys help me to see where is the error?
Here is the code who has the arduino, here is a BMP085 and only one Dallas DS18b20.
[code]#include <Sleep_n0m1.h>
#include <SPI.h>
#include <EEPROM.h>
#include <DallasTemperature.h>
#include <OneWire.h>
#include <RF24.h>
#include <Sensor.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
// Set RADIO_ID to something unique in your sensor network (1-254)
// or set to AUTO if you want gw to assign a RADIO_ID for you.
#define RADIO_ID 5
#define ONE_WIRE_BUS 3 // Pin where dallase sensor is connected
unsigned long SLEEP_TIME = 30; // Sleep time between reads (in seconds)
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
Adafruit_BMP085 bmp = Adafruit_BMP085();
Sensor gw(9, 10);
Sleep sleep;
#define MAX_ATTACHED_DS18B20 16
float lastTemperature[MAX_ATTACHED_DS18B20];
int numSensors=0;
boolean metric = true;
float lastPressure = -1;
float lastTemp = -1;
int lastForecast = -1;
char *weather[] = {“stable”,“sunny”,“cloudy”,“unstable”,“thunderstorm”,“unknown”};
int minutes;
float pressureSamples[180];
int minuteCount = 0;
bool firstRound = true;
float pressureAvg[7];
float dP_dt;
void setup()
Serial.begin(BAUD_RATE); // Used to type in characters
sensors.begin();
gw.begin(RADIO_ID);
// Fetch the number of attached sensors
numSensors = sensors.getDeviceCount();
// Register all sensors to gw (they will be created as child devices)
for (int i=0; i<numSensors; i++) {
gw.sendSensorPresentation(i, S_TEMP);
gw.sendSensorPresentation(1, S_BARO);
gw.sendSensorPresentation(2, S_TEMP);
metric = gw.isMetricSystem();
if (!bmp.begin()) {
Serial.println(“Could not find a valid BMP085 sensor, check wiring!”);
while (1) {}
void loop()
sensors.requestTemperatures(); // Fetch temperatures from Dallas
delay(100);
Serial.println(“Holaaaa”);
Serial.print(“Temperature = “);
Serial.print(bmp.readTemperature());
Serial.println(” *C”);
Serial.print("Pressure = ");
Serial.print(bmp.readPressure());
Serial.println(" Pa");
// Fetch and round temperature to one decimal
float temperature = static_cast(static_cast((metric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
// Only send data if temperature has changed and no error
if (lastTemperature[i] != temperature && temperature != -127.00) {
gw.powerUp(); // Powerup introduces a small delay (which is missing in radio.write powerup)
// Send variable (using registered shortcut) to gw
gw.sendVariable(i, V_TEMP, temperature, 1);
lastTemperature[i]=temperature;
float pressure = bmp.readPressure();
float temperature = bmp.readTemperature();
if (!metric) {
// Convert to fahrenheit
temperature = temperature * 9.0 / 5.0 + 32.0;
//int forecast = sample(pressure);
Serial.print(temperature);
Serial.println(metric?” *C”:" *F");
Serial.print(“Pressure = “);
Serial.print(pressure);
Serial.println(” Pa”);
//Serial.println(weather[forecast]);
if (temperature != lastTemp) {
gw.sendVariable(2, V_TEMP, temperature,1);
lastTemp = temperature;
if (pressure != lastPressure) {
gw.sendVariable(1, V_PRESSURE, pressure, 0);
lastPressure = pressure;
//if (forecast != lastForecast) {
// gw.sendVariable(1, V_FORECAST, weather[forecast]);
// lastForecast = forecast;
DP/Dt explanation
0 = “Stable Weather Pattern”
1 = “Slowly rising Good Weather”, "Clear/Sunny "
2 = "Slowly falling L-Pressure ", "Cloudy/Rain "
3 = “Quickly rising H-Press”, “Not Stable”
4 = “Quickly falling L-Press”, “Thunderstorm”
5 = "Unknown (More Time needed)
// Power down the radio. Note that the radio will get powered back up
// on the next write() call.
delay(500);
gw.powerDown();
sleep.pwrDownMode(); //set sleep mode
sleep.sleepDelay(SLEEP_TIME * 1000); //sleep for: sleepTime
int sample(float pressure) {
// Algorithm found here
// http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
if (minuteCount > 180)
minuteCount = 6;
pressureSamples[minuteCount] = pressure;
minuteCount++;
if (minuteCount == 5) {
// Avg pressure in first 5 min, value averaged from 0 to 5 min.
pressureAvg[0] = ((pressureSamples[1] + pressureSamples[2]
+ pressureSamples[3] + pressureSamples[4] + pressureSamples[5])
/ 5);
} else if (minuteCount == 35) {
// Avg pressure in 30 min, value averaged from 0 to 5 min.
pressureAvg[1] = ((pressureSamples[30] + pressureSamples[31]
+ pressureSamples[32] + pressureSamples[33]
+ pressureSamples[34]) / 5);
float change = (pressureAvg[1] - pressureAvg[0]);
if (firstRound) // first time initial 3 hour
dP_dt = ((65.0 / 1023.0) * 2 * change); // note this is for t = 0.5hour
else
dP_dt = (((65.0 / 1023.0) * change) / 1.5); // divide by 1.5 as this is the difference in time from 0 value.
} else if (minuteCount == 60) {
// Avg pressure at end of the hour, value averaged from 0 to 5 min.
pressureAvg[2] = ((pressureSamples[55] + pressureSamples[56]
+ pressureSamples[57] + pressureSamples[58]
+ pressureSamples[59]) / 5);
float change = (pressureAvg[2] - pressureAvg[0]);
if (firstRound) //first time initial 3 hour
dP_dt = ((65.0 / 1023.0) * change); //note this is for t = 1 hour
else
dP_dt = (((65.0 / 1023.0) * change) / 2); //divide by 2 as this is the difference in time from 0 value
} else if (minuteCount == 95) {
pressureAvg[3] = ((pressureSamples[90] + pressureSamples[91]
+ pressureSamples[92] + pressureSamples[93]
+ pressureSamples[94]) / 5);
float change = (pressureAvg[3] - pressureAvg[0]);
dP_dt = (((65.0 / 1023.0) * change) / 1.5); // note this is for t = 1.5 hour
else
dP_dt = (((65.0 / 1023.0) * change) / 2.5); // divide by 2.5 as this is the difference in time from 0 value
} else if (minuteCount == 120) {
pressureAvg[4] = ((pressureSamples[115] + pressureSamples[116]
+ pressureSamples[117] + pressureSamples[118]
+ pressureSamples[119]) / 5);
float change = (pressureAvg[4] - pressureAvg[0]);
dP_dt = (((65.0 / 1023.0) * change) / 2); // note this is for t = 2 hour
else
dP_dt = (((65.0 / 1023.0) * change) / 3); // divide by 3 as this is the difference in time from 0 value
} else if (minuteCount == 155) {
pressureAvg[5] = ((pressureSamples[150] + pressureSamples[151]
+ pressureSamples[152] + pressureSamples[153]
+ pressureSamples[154]) / 5);
float change = (pressureAvg[5] - pressureAvg[0]);
dP_dt = (((65.0 / 1023.0) * change) / 2.5); // note this is for t = 2.5 hour
else
dP_dt = (((65.0 / 1023.0) * change) / 3.5); // divide by 3.5 as this is the difference in time from 0 value
} else if (minuteCount == 180) {
pressureAvg[6] = ((pressureSamples[175] + pressureSamples[176]
+ pressureSamples[177] + pressureSamples[178]
+ pressureSamples[179]) / 5);
float change = (pressureAvg[6] - pressureAvg[0]);
dP_dt = (((65.0 / 1023.0) * change) / 3); // note this is for t = 3 hour
else
dP_dt = (((65.0 / 1023.0) * change) / 4); // divide by 4 as this is the difference in time from 0 value
pressureAvg[0] = pressureAvg[5]; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
return 5; // Unknown, more time needed
else if (dP_dt < (-0.25))
return 4; // Quickly falling LP, Thunderstorm, not stable
else if (dP_dt > 0.25)
return 3; // Quickly rising HP, not stable weather
else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
return 2; // Slowly falling Low Pressure System, stable rainy weather
else if ((dP_dt > 0.05) && (dP_dt < 0.25))
return 1; // Slowly rising HP stable good weather
else if ((dP_dt > (-0.05)) && (dP_dt < 0.05))
return 0; // Stable weather
else
[/code]
Thanks to all.
