Hello,
I have been using the plugin for my PowerMax Pro for some time now and I am very satisfied with it. And I have to give big thanks for the developer.
But I have a request, if it is possible of course.
I have 2 partitions which it is known not to be supported for PowerMax Pro as separate ones. So there is only one partition created for both. The problem is that the only way to separate them is through the status of the panel.
I have some actions triggered according to the Partition status (Device is Armed, Device is Disarmed), but unfortunately if one partition is armed, the trigger “Device is Disarmed” is not recognized since the device is already armed.
The only way to overcome this problem and being able to trigger actions for each partition separately, is through the Panel status. But the panel does not have support for that as the only triggers/notifications are “Alarm Type” and “Trouble Type”.
Is it possible to add a triggers/notifications at the panel device for status change? It would be very helpful for for a lot of things.
Thank you in advance.
