Hello,
I’ve scanned through quite a few search results but have not been able to find an answer to my current situation.
I currently have an X10 setup and I’m in the process of converting to Z-Wave. So far, I have a Vera3 and 15 Leviton VRPD3-1LW lamp modules. In my X10 setup, I have a HomeRunner RBI connected to a PowerLinc Modem 2412S (v3.5 1027 if it matters). Currently, the 2412S connects to the serial interface on the HomeRunner via a standard RJ45 cable. The jack on the 2412S is not an Ethernet interface. It is an RJ45 jack that is just labeled “Interface Cable”.
So, my question is…what cable should I use to connect the 2412S to the Vera3? If such a beast doesn’t exist, I think I could take one of my APC UPS USB interface cables and hack something together. But…I will need to know what the pinouts on both ends. Help!
