I upgraded to the latest version using the interface and now the power light just keeps flashing on and off again. From my understanding, this means that the flash is corrupted.
Here is the version that I downloaded:
http://download.mios.com/betafirmware/wl500gP_Luup_ui3-1.1.329-1.trx
I tried to follow the instructions here:
http://wiki.micasaverde.com/index.php/Firmware_Flash
“If Vera’s power light blinks consistently (not a double pulsing blink) within a few seconds of powering on, then Vera’s firmware has become corrupted. This can happen if Vera was unplugged while in the middle of performing a firmware update (“flash”). When it does, you will probably need to use a firmware restoration utility, which runs on Windows. Here is how to restore Vera’s firmware once it has become corrupted:”
However, flash_firmware.zip is no longer on the server. Can someone please help?
