This issue had me going crazy for a week, my workaround is at the bottom.
Hello, I also own 2 GoControl LB60Z-1 bulbs. One is installed in a living room lamp, the other I recently installed in my bedroom lamp. Before purchasing the bedroom bulb I noticed that the living room lamp bulb would turn on during the night if I had accidentally turned the lamp’s knob to turn-off the bulb. I would quickly turn the knob back on realizing what I had done (which would turn the light on), then I would turn off the lamp with the mobile app. I would then go to sleep. After waking up in the morning, I would come downstairs and notice the bulb was on. It was very creepy until I picked up on the pattern.
I liked the functionality of the bulb so much that I decided to purchase another for my bedroom lamp. I have an Amazon Dot in my bedroom which I can use to control all my Z-Wave devices. It was great being able to shut the lamp with voice commands from bed. It was great until the bedroom lamp turned on by itself EVERY SINGLE NIGHT AT 2 AM. I realized that it must be due to me or my wife accidentally using the wall switch by the door to turn the lamp on and off as we had done for 3 years prior. So we told ourselves, NEVER TOUCH THE SWITCH. But somehow, someway, the switch accidentally gets used and then we wake up at 2am yelling at Alexa (Amazon Dot). Yes, I know the bulb came with a wall switch guard that prevents you from switching, but I thought, hmm I actually might want to use the switch once in a while. What harm could that do?
So here are the scenarios that may cause the bedroom bulb to lose power causing us to wake up at 2am.
- Wall switch was used.
- Lamp twist knob was accidentally used.
- Lamp plug was temporarily removed from the wall outlet to plug-in another device - hair dryer, fan, radio, etc.
- Power loss at the house
The suggested scenarios to create a scene or trigger to turn off the bulb nightly at 2:01am or to turn off the bulb when an on-state is detected will not work for me. It will not work because as soon as the bulb turns on for 1 second, the wife starts screaming.
So the nightly heal happens around 2am triggering the light to turn on if it had lost power since the last heal. There used to be a way to manually heal but that does not exist in the current UI. I found a forum that describes a URL you can use to manually heal but one user reported a very negative experience.
So here’s how I found to “manually heal”, preventing the 2 AM nightmare.
-Restore power to the bulb (the bulb will turn on).
-Turn the bulb OFF with the Vera app.
-Using a browser, not the mobile app, log into your dashboard (either by going to home.getvera.com or by using the IP address of the Vera)
-Go to devices and select the bulb that had lost power.
-Scroll down (if needed) and click on “Device Options”.
-Click “Update Neighbor Nodes”, then click OK when the window pops-up.
-Your bulb should blink then stay on.
-You can now turn your bulb OFF with via Vera.
-Sleep through the night without an angry wife.
In the end, here is my workaround:
-Buy a wall switch guard (I threw away the one that came with the bulb).
-Be aware of any power loss described in the scenarios above.
-If power loss is detected, update the neighbor nodes.
Sooo does anybody know of a bulb that does not have these problems??
