From my post in the AltUI forum http://forum.micasaverde.com/index.php/topic,52306.0.html, I cannot seem to close the VeraAlerts config window when using it from AltUI. It was suggested to look in the JavaScript log, and indeed I found an error:
Use of getPreventDefault() is deprecated. Use defaultPrevented instead.
jquery-1.9.1.min.js:3:31293
Source map error: request failed with status 404
Resource URL: https://vortex.accuweather.com/adc2010/oap/javascript/jquery-1.9.1.min.js
Source Map URL: jquery.min.map
The altUI author mentioned it might have to do with the JQuery version:
Altui is using latest jquery 3.2.1 maybe veraalert uses older version and something is failing, you should see an error
-Ted
