Possible to run vera on vmware??
Hi
Is it possible to run the vera software inside a develop environment like vmware ?
i know it´s possible to run a x86 version of openwrt inside vmware…
If you can get vmware work as a broadcom cpu you can budt else not.
No it’s not possible because Vera has it’s binaries compiled for MIPS CPU. You could probably use the automation part in an emulator that has MIPS CPU emulation support, like QUEMU.
