Mitch,
Actually, what I’m going to do is let an electrican install two Intermatic CA3000’s on two different sets of existing lights. These are priority projects for me.
I’m going to put off being my own electrician for a couple of months or longer. Electrical, gas, and even water work requires a lot of certainty for DIY’ers. I simply don’t have the time to read up to the point where I’m absolutely confident in my abilities–right now.
I found a website (automatedoutlet-com) which sells these CA3000 for $34.95 a piece. Not quite Radio Shack liquidation prices but pretty close, given that these often go for $90. I spoke to the tech suppport guy and he told me they bought over 50,000 discontinued Intermatic products, which included these CA3000’s at a tiny fraction of the normal rate for retailers. Thus, they were passing on the savings.
He also told me that these CA3000 were very high quality, contrary to what you’re saying. Frankly, I don’t know what to make of it. He is an electrician and you’ve installed a lot of stuff yourself. Nothing else you’ve posted contradicts the tech support from Jasco or AutomatedOutlet.
The CA3000 has its own auxiliary slave switches, but he warned me they may not work with the GE Smart remotes or remotes of other brands since Intermatic didn’t strictly adhere to Z-Wave protocols when they designed the CA3000’s auxiliary slaves. EDIT: He did confirm, as did the Jasco techie, that the CA3000 itself is fully compatible with other remotes, namely GE.
The added bonus for me is he told me the CA3000 should be compatible with my motion detector manual override switch (a different set of lights), which the techie at Jasco couldn’t tell me, i.e. compatibility with GE.
However, for the CA3000 to work with traditional switches, the traditional switches would have to be in one of the many various “ON” configuration in my 3 & 4-Way switches. For me this is not a problem. As long as the remote can turn the lights on and off.
Since I’m currently doing a number of other (non-electrical) upgrades for my house, cost is an issue. I figure the cost here will be 2 x $34.95 + $80 (electrician). The electrican I’m looking at has high ratings from AngiesList. I’m certain the guy can probably do both in less than an hour; otherwise it’s an additional $25/15min. I can part with $150 for not one, BUT TWO different sets of lights.
On the other hand, the cost of replacing all four switches is to buy 3 kits at $65/each (might as well since I’m going to need another primary for the motion detector override–assuming compatibility) + replacing the manual override switch for the motion detector may exceed $350. And there’s no guarantee the GE slaves will work with my wiring.
Thanks again Mitch. Yours and Kaldoon’s posts were quite important for my online recon.
P.S. Much of my posting here is to help inform others who are considering alternatives.
P.P.S. The techie from Jasco was unable to 100% definitively tell me that a single GE Primary (with no GE auxiliaries) is not compatible with traditional switches. She only told me that they were not intended to work along side traditional switches. So there’s still a little wiggle room here. Of course, she seemed 99.9% certain that it couldn’t be done.
