Porch Light
Need help with turning porch light on 1 hour after sunset, making it 50% bright at midnight and turning off 1 hour before sunrise. Probably explanined somewhere, can’t find. Please help
If you wanted to use those specific times, I believe you will have to set up 3 different timers.
First timer…daily…“before sunset”…turn on.
Second timer…daily…“2400 hours”…dim to 50%.
Third timer…daily…“before sunrise”…turn off.
Or with one timer you could ballpark it.
Set timer daily for “before sunset”
Then commands for the light like this…
Turn on…then after about 5 hours dim to 50%…ect…
