I’m trying to code some lua to adjust the setpoint of the radiator thermostat.
the following code changes the parameter value, as seen in the “advanced settings” showing all values:
luup.call_action("urn:upnp-org:serviceId:TemperatureSetpoint1_Heat", "SetCurrentSetpoint", {NewCurrentSetpoint = userTemperature}, dev_Id)
However, the user interface value does not reflect this in the vera UI nor does it actually transmit the value to the device. Adjusting via the + or - buttons on the UI works as expected.
I’m aware that any adjustment i do only gets updated every 30mins or so when the device polls for an update.
any advice on this appreciated. thanks
still happily running UI v5
