I’m trying to install plugins and considering the instructions it should be really easy. However, the plugins don’t appear when I’ve created a device. I’ve tried two plugins now and I have run out of ideas.
I follow the instructions that were roughly the same for both plugins apart from the moment of restart. All is well while uploading the files, all 4 files appear in the LUUP-files list. Subsequently, I try to create the device, which isn’t very complicated according to the description. I enter the name of the D_xxxx.xml file into the UpnpDevFilename field and set a Description. I mind the caps and such. Then I click the create device button, which doesn’t give any feedback, but I’m certain I clicked it. Then I close the Mios Developers panel and Save and Reboot and Save some more… But at no point I see any sign of a new device appearing on the Dashboard.
It should be on the Dashboard right? Is there any setting that could explain this behavior? I don’t have a clue anymore. It should just work this way according to three installation instructions that I’ve read. ???
I’m no longer on UI4, but I have a recollection that you get feedback when you click the “Create Device” button. I thought that an alert popped up that you had to dismiss. Can any UI4 people confirm or deny?
I used IE9 on windows 7 and the device appeared right away. I did get feedback after pressing the create device button. I didn’t try this before because it was mentioned in the instructions not to use IE.
Conclusion: creating a device on Mac OS X is broken in UI4 on at least FireFox and Safari. Is there any chance that MCV reads this and looks into the issue? Or should I register the problem somewhere?
[quote=“apt, post:5, topic:170567”]I’ve made progress…
Thanks for the attempts to help![/quote]
FWIW Creating devices on Mac OSX UI5 works fine on all browsers (Chrome, Firefox, Safari).
