A new version is available (on an experimental basis) in this post…
v0.19dev22 - September 16, 2015 (Manual update only)
added - initial support for the Lutron Connected bulb Remote
Updated files:
L_Wink_Hub1.lua
The Lutron Connected Bulb Remote is only usable in “REMOTE” or “COMBINED” API mode, and requires:
a Wink Hub with Firmware 2.19 or greater
OR *
a Wink Relay with Firmware 1.0.305 or greater.
(The remote can only be paired with a Wink Hub or Wink Relay - It will not pair with a GE Link Hub or a Philips Hue hub).
The Wink Connect plugin will create a scene controller for each Lutron Connected Bulb Remote that is paired to your Wink Hub or Wink Relay.
BUTTON ASSIGNMENTS:
1 = On
2 = Up
3 = Down
4 = Off
The Lutron Connected remote does not support button held events, but holding the up or down button will cause the Wink API server to generate multiple button press events…
Hmm, I am on .19 (store release) on UI7, and suddenly my Wink Devices have been renamed to be prefixed with the word “[Firmware]” at the beginning. I have tried to rename them back, but after a LUA restart they revert back.
Is there anythign that needs done after uploading those files or hsould I be uploading something else?
I get the following message at the top of my screen:
Wink_Connect: Unsupported MIOS version
and also Device not ready in the settings of the device no matter that I click. Can someone please assist?[/quote]
I updated to UI7 and now it is working properly on the web browser, However my Vera app just shows the egg minder as turn off or on device instead of telling me the info, any suggestions for this?
Wondering if there is a way to configure the plugin so that only one or two devices or shortcuts from Wink are accessable from Vera. My scenario is I only need to do this for a device or two (or shortcuts), so that the Vera can trigger an event based on the device/shortcut status. I do not need access to all the other Wink stuff from vera
[quote=“cybrmage, post:611, topic:185289”]Version 0.20 has been uploaded to the App Marketplace, and is pending approval.
It is also available, for manual installation, attached to the first post in the thread.[/quote]
I was running the most recent beta and I uploaded the new L_Wink_Hub1.lua to get me to 0.20 and got an error saying “FILES MISMATCH”. I uploaded all of the new files and am still getting that error under the status of the plugin. Any idea how to fix it?
[quote=“wezley69, post:617, topic:185289”]Uploaded all of the files. Everything appears to work but I am getting a LUUP restart every 10 minutes on the button.
After removing the plugin the restarting ceased.
Thoughts?[/quote]
Need the LuaUPnP log (with debug enabled) to see what’s going on.
[quote=“wezley69”]Loaded .19 from MIOS LUUP restart at 30 minutes. Update to .20 and now back to 10 minute LUUP restarts. Verbose logging set. Here is the log.
Zipped and still to large to upload to the forum. Suggestion?[/quote]
Dropbox is perfect for sharing files like this.
