PLUGIN: Wink Connect (formerly Wink Hub Controller)
NEW VERSION - available in first post
v0.18b91 - July 28, 2015 (manual update only)
– Fixed - REMOTE/COMBINED MODE - plugin would not process devices properly if a Wink Hub/Wink Relay was not attached to the Wink Account
[quote=“Jim McGhee, post:519, topic:185289”]It works!!!
Thanks for the quick turnaround. ;D
Not meaning to be picky, but… ::slight_smile: When you edited the original post you did fix the last two but it still shows S_Wink_PicoRemote1.json instead of S_Wink_PicoRemote1.xml.
Thanks again, my new pivots are now useful (I ordered two more).[/quote]
Excellent… glad it’s working… (I hate it when Quirky fixes a bug and doesn’t mention it anywhere 8-} )
I’d order a few, but walmart.com won’t ship to the great white north, and I refuse to pay $50 retail + $35 shipping from Quirky…
They’ll eventually be stocked at HD up here, and I’ll pick up a few when they inevitably go on clearance 8-}
Ok… The plugin was originally designed to control a Wink Hub… and has expanded to include the standalone and linked services that do not require a Wink Hub… But… the plugin was still expecting a Wink Hub…
That has been fixed… A new version will be posted shortly…
Since you are running the App Marketplace version, you WILL need to upload all the files in the archive to your Vera…[/quote]
You’re the best!!! That did the trick. The garage door now appears in my device list with opened or closed options. 8)
The open and close status doesn’t update unless i re-sync the wink connect. Do you have any tips or tricks to force it to update the status? It doesn’t have to be instant, but I’d like to have it update without me manually re-syncing.
I don’t know if this plugin has anything to do with the mobile vera app or not but the garage door appears as an On/Off switch and I couldn’t get it to open and close the garage door from the mobile vera app on my iphone.
I appreciate all your effort maintaining this app!
Did you change your client mode to notifications?? (no… you didn’t… your logs show you had it set for POLLED)… In notification mode, the Wink API servers will send a notification when a devices state changes… this provides as-close-to-instant status updated as possible… In polled mode, the plugin receives the device state as the response from the open/close command, but with many devices (and especially with a linked service) this “updated” state is usually provided BEFORE the device actually changes state… although the plugin tries to accommodate for this, it is not always possible… The correct device state will be retrieved from the Wink API servers at the new device poll (by default, the plugin polls every 60 seconds) without the need to resync…
So… Short answer… change to NOTIFICATION mode.
The Vera Mobile app has nothing to do with the Wink Connect plugin… The Garage door devices use a custom deviceType, so that they appear in the UI with the garage door icons and the “opened”/“closed” wording… The garage door devices implement the functionality of a door lock device, so I am surprised that the mobile app sees them as an on/off switch… But that is probably why it doesn’t work (it will be sending the wrong command to the device) and it probably will not display the correct state either…
If you provide the logs of the mobile app sending the open/close command, I can try to accommodate the command it sends (as long as the changes would not break anything else the plugin does)…
Alternately, you can ask the mobile app author to support the custom device types used in the plugin…
I’m not sure how to obtain the logs from the mobile app. I’ve only been at this for about a week so I’m still learning the ropes.
Could you help explain how to access the mobile app logs?
Thanks!
[quote=“GoogleNinja, post:525, topic:185289”]I’m not sure how to obtain the logs from the mobile app. I’ve only been at this for about a week so I’m still learning the ropes.
Thanks![/quote]
No… I don’t need the logs from the mobile app…
I need the LuaUPnP log from Vera… Same as the last log, except - start capturing the logs then try to open/close the garage door using the mobile app… then post the LuaUPnP log.
How do I gt my Chamberlain MyQ opener to show up in the “My Shortcuts” section in Vera? Can we change it from “On/Off Switch” to “Garage Door(s)” or something? Is there any way to make it look/work like the garage door in the wink app and the myq app?
tia…
[quote=“holeyman, post:527, topic:185289”]How do I gt my Chamberlain MyQ opener to show up in the “My Shortcuts” section in Vera? Can we change it from “On/Off Switch” to “Garage Door(s)” or something? Is there any way to make it look/work like the garage door in the wink app and the myq app?
tia…[/quote]
Not sure how to get anything other than “All lights” and “All locks” to show up under my shortcuts, but I have my doors added as favorites so they still show up on the dashboard. Mine show the garage icon though and not the generic Z-wave icon.
[quote=“dubbedout, post:528, topic:185289”][quote=“holeyman, post:527, topic:185289”]How do I gt my Chamberlain MyQ opener to show up in the “My Shortcuts” section in Vera? Can we change it from “On/Off Switch” to “Garage Door(s)” or something? Is there any way to make it look/work like the garage door in the wink app and the myq app?
tia…[/quote]
Not sure how to get anything other than “All lights” and “All locks” to show up under my shortcuts, but I have my doors added as favorites so they still show up on the dashboard. Mine show the garage icon though and not the generic Z-wave icon.[/quote]
OK, I guess I just need “all locks” then. Yeah, it’s a favorite for the dashboard already. :wink:
I don’t know why I have a different icon, I did a full upload of the latest beta and have the latest firmware. My wink hub uses the same generic icon, is that wrong too?
[quote=“holeyman, post:529, topic:185289”]OK, I guess I just need “all locks” then. Yeah, it’s a favorite for the dashboard already. :wink:
I don’t know why I have a different icon, I did a full upload of the latest beta and have the latest firmware. My wink hub uses the same generic icon, is that wrong too?[/quote]
I don’t know if thats possible since it’s just seen as an On/Off switch on Vera. All my Wink devices show their appropriate icons. They’re located in /cmh/skins/default/img/devices/device_states. If you browse to that directory on your Vera you should see a bunch of Wink icons.
[quote=“dubbedout, post:530, topic:185289”][quote=“holeyman, post:529, topic:185289”]OK, I guess I just need “all locks” then. Yeah, it’s a favorite for the dashboard already. :wink:
I don’t know if thats possible since it’s just seen as an On/Off switch on Vera. All my Wink devices show their appropriate icons. They’re located in /cmh/skins/default/img/devices/device_states. If you browse to that directory on your Vera you should see a bunch of Wink icons.[/quote]
Is there a file browser in vera that I’m missing? I can’t seem to find where to download the log file either…
I either SSH into Vera or use WinSCP. From the Vera WebUI, click Apps, Develop Apps, Luup Files. You’ll get a list of all the files, and you should see all the Wink icon files as well.
Here’s a list of all my Wink images:
I didn’t even think to try ssh/scp.
I don’t see the log file but I do have those png’s…
EDIT:
SSH fails; it appears that it’s not enabled and I’m not sure what to do next. It took a minute to find the IP in vera’s “Net & WI-FI” section too…
Post-EDIT EDIT:
OK I got SSH working and found the log location: /tmp/log/cmh/LuaUPnP.log
let me start with, I searched for the answer without any luck. I am using a stock wink hub and have 3 ge lights and my garage door connected. I can get everything loaded into vera and control the devices. but if I use my wink app to turn on/off the light or open the garage, it won’t updated the status in vera. I have the wink configured to remote and I have tried both polled and notifications. the on;y way I can get the status to update is with a manual resync. am I missing something or is this how it is supposed to function?
I’ve noticed similar behavior, where the lights sync after beta .lua updates but then stop after some amount of time. Like you, manual reloads or .lua uploads will start syncing again. Must be a bug.
tia…[/quote]
Your Vera device for the MYQ garage door opener must have somehow got the old deviceType (from the UI5 only support)… If you delete the device in Vera and do a LuaUPnP engine reload, it should be recreated with the correct deviceType and json file…
I’ve noticed similar behavior, where the lights sync after beta .lua updates but then stop after some amount of time. Like you, manual reloads or .lua uploads will start syncing again.[/quote]
Maybe… But I can’t reproduce it… My production system (that gets updated to the latest version when I post it) has no issues with device updates… last reload was two days ago… still working…
So… If you can provide loags (going as far back as possible… maybe I can figure out what is happening…
So… If you can provide loags (going as far back as possible… maybe I can figure out what is happening…[/quote]
I’ve had to do it more than once since installing (full upload) b91 even. I wonder if manually using wall switches to turn on a light instead of the app has anything to do with losing sync?
I found my log. I just switched it to the Wink Connect recently so you won’t have to go back too far. Debug wasn’t on very long so if you need debug on longer let me know and I’ll rename the log and let it start a new one with debug on…or whatever you need. :wink:
[quote=“cybrmage, post:536, topic:185289”][quote=“holeyman, post:527, topic:185289”]How do I gt my Chamberlain MyQ opener to show up in the “My Shortcuts” section in Vera? Can we change it from “On/Off Switch” to “Garage Door(s)” or something? Is there any way to make it look/work like the garage door in the wink app and the myq app?
tia…[/quote]
Your Vera device for the MYQ garage door opener must have somehow got the old deviceType (from the UI5 only support)… If you delete the device in Vera and do a LuaUPnP engine reload, it should be recreated with the correct deviceType and json file…[/quote]
I just added it and it got the wrong one. I tried the delete/reload anyway but it still has the wrong icon. I did notice that all of the WINK*.png files in the /cmh/skins/default/img/devices/device_states dir had different permissions than the other files so I made them like the others but that didn’t help either.
Manually changing a device state at a wall switch should not affect the sync (unless you are using a wallswitch to remove power from a smart-bulb - in which case, nothing will be able to determine its status)
Totally unneed and ineffective… The plugin has the icons embedded in it, and it recreates them and copies them to the correct directory (determined by the UI version the Vera is running) every time the plugin is started… So the permissions will be reset… As long as the files has read permissions, everything is good…
Did you refresh your browser??? the browser caches the device json, and even if the LuaUPnP engine is restarted and a new device json is loaded, the browser will not pick up the change until it is forced to refresh its cache…
The MYQ garage door device in Vera is getting the correct device type and device file, so the image should be of a garage door…
As the category definition in Vera for a garage door is actually a subcategory of a binary switch (Category 3 = binary switch, Subcategory 5 = garage door), the device will appear as an on/off switch in the device list and dashboard… If it really bugs you, you can go to the device settings (advanced tab) and change the category to 7 (door lock), and the device will then appear as a door lock (and yes, the plugin does the wink<=>vera translations so that locked = closed and unlocked = open)… In the dashboard, clicking on “lock all” will lock your locks and close your garage doors… Just be aware that clicking on “unlock all” will unlocck your locks and open your garage door…
As for your logs… a few things I noticed:
  1. In the two hour durations of the logs, the LuaUPnP engine reloaded six time… Only one of those reloads was due to an error… because the Wan IP changed… most of the others were due to the wan ip change
  2. You need to fix your IP Camera… It’s refusing connections with a “401 unauthorized” error, and the debug output is very verbose.
  3. the Wink Connect plugin appears to be operating correctly… there are no failures (plugin crashes) and the only errors it had were duing the multiple reload cycle caused by the wan ip change (it could not retrieve the device list because the network was not up)… It is receiving notifications from the Wink API server and there is no indication that the connection to the notification server is disconnected.
Right, I leave the switches on but when I need a light and the app isn’t handy I’ll just use the switch to bypass. It was just an idea, if that’s not it…ok. :wink:
I did refresh the browser and my android app shows the same (wrong) icons for both the hub and the myq too.
I did some network changes but that was unrelated.
The IP camera works fine when using the web-vera but when I use the android one the camera is just black, I assume that’s where the errors are coming from.
I don’t know why it does it but I woke up and had to refload the lua again today, turning on lights via wink did not get picked up by either web-vera nor android vera.
