Yes I renamed to local_api.php. Copied to /var/www on Wink. Change permission to 0700 … but still got the same no usable local hubs
Then you will need to turn on debug mode, reload the LuaUPnP engine, and post the LuaUPnP.log so I can see what’s going on…
Then you will need to turn on debug mode, reload the LuaUPnP engine, and post the LuaUPnP.log so I can see what’s going on…[/quote]
Attached is the whole log … my Wink IP is x.x.x.165 … I gotta zip up the log as it’s over the attached size allowed.
Yep… Definately not finding thw Wink Hub…
It may be that your Wink Hub has a MAC address outside of the range of values that the plugin is looking for…
Try loading a browser and go to “http://(ip address of Wink Hub)/local_api.php?getDeviceList=true”… The Wink hub should respond with the list of devices attached to the hub… The first entry will have the MAC address for the hub (labeled “hub_mac”)… I need to know the first eight digits… Thanks.
Try loading a browser and go to “http://(ip address of Wink Hub)/local_api.php?getDeviceList=true”… The Wink hub should respond with the list of devices attached to the hub… The first entry will have the MAC address for the hub (labeled “hub_mac”)… I need to know the first eight digits… Thanks.[/quote]
The first 8 digits of the MAC address labeled hub_mac is b4:79:a7:17
Yep… Different mac address range…
Try this…
I loaded v1.7 and now the UI wont load. Is there a way I can disable the Wink Plugin via SSH, so I can get a functioning unit again and then reload the plugin?
Try this…[/quote]
Thanks for the quick response … the attached files worked. Now I am running local. Just wondering, once I switch to local and reloaded/resynced, the existing set of devices were removed and a new set of devices are added … but now the refuel is missing, probably not support in local mode …
Local mode only supports devices that are connected directly to the Wink Hub…
Devices that are not supported in wink mode include: Quirky Refuel, Quirky Porkfolio, Quirky Spotter, MYQ garage door openers, any device attached to a Wink Relay, any device or service that is linked to your Wink Account…
Attached is a quick update to allow devices to display correctly on the new release of UI7 (v7.0.5 - 1.7.1018)…
A quick update to (attempt to) resolve an issue with the Quirky Eggminder.
Log with eggminder
I think egg 7 and egg 13 are swapped in the plugin because I am using spots 1-12 and nothing in 13 and 14.
See screenshots
Nope… The numbering is TOTALLY wrong… I displayed them left to right, top to bottom… Wink displays them bottom to top, left to right…
Attached is a fix… It also includes fixes (derived from your logs) for the Porkfolio…
Works. Porkfolio shows savings and goal and it is correct. Porkfolio also has sensor(s). It knows if it has been moved and knows if it has been flipped over to be emptied. Wink sends an alert on each one of these events. Another item it does is you change the color of the nose when it lights up after you have put money in. Changing the color of those isn’t all that useful in Vera but t triggering the sensor (accelerometer?) in porkfolio could be. You could put porky behind a closed door or something when on vacation.
Great work so far!
Hmmm… The Wink API documentation does not make any mention of the sensors at all… If you turn on debug mode and trigger the sensors and post the notification processing, I should be able to do something with the sensors…
I am using remote API and I have to say my light commands on Vera to wink bulbs has been a bit snappier.
A few weeks ago I picked up another wink hub at Home Depot with hopes of rooting it to go local. The one I picked up (was the only one in the end cap) must have been previously purchased because it had updated firmware so I returned it. The returns cashier tagged it “Return to Vendor.” I asked why because it was still new and sellable. She told me it was because they were no longer carrying it in the store. Very curious because they had a huge endcap of wink and z-wave stuff. I don’t see HD retreating from wink and HA. Possible a wink hub replacement is coming from GE/Quirky?
[quote=“FOCGreeN, post:236, topic:185289”]I am using remote API and I have to say my light commands on Vera to wink bulbs has been a bit snappier.
A few weeks ago I picked up another wink hub at Home Depot with hopes of rooting it to go local. The one I picked up (was the only one in the end cap) must have been previously purchased because it had updated firmware so I returned it. The returns cashier tagged it “Return to Vendor.” I asked why because it was still new and sellable. She told me it was because they were no longer carrying it in the store. Very curious because they had a huge endcap of wink and z-wave stuff. I don’t see HD retreating from wink and HA. Possible a wink hub replacement is coming from GE/Quirky?[/quote]
I did the same thing a few days ago and when they scanned it the system it said it wasn’t carried in the store. They still had 1 hub sitting on the shelf too, but not many accessories.
[quote author=cybrmage link=topic=30007.msg224345#msg224345 date=1425913435]
[quote=“bazzly, post:216, topic:185289”]Hmm… Thanks, I’ll have to give that a go when I have a moment. Looks like I’ll have to see if I can undo what I did, and try those instructions.
Keeping my fingers crossed!![/quote]
You shouldn't have to "undo" anything... just follow the instructions at the rootwink.com site and you should be fine... When adding the lines to the /etc/hosts file, leave out the "hub-api.winkapp.com" line - so that the hub can communicate with the API server...
Took a little work, but have everything working…I think!
When I have more time to play, I’ll post back.
Thanks!
With that said about HD, Target now carries some Wink stuff on its site. BOGO 50% off wink GE quirky stuff including the Aros AC unit and Quirky never lets you use promo codes on it on their site.
Wow, local is snappy! A lot quicker than using remote, or the Wink app its self.
