Friends,
Ok, so I have built RelayActuatorWithButton, and has been working well with vera3.
But when I unplug the vera3, the button does not turn on the relay.
Please help to solve this problem.
Friends,
Why are you turning off Vera?
The example sketch confirms that your push message has successfully reached Vera before switching actual relay-status.
If you want it to work independent of vera you’ll have to make modifications. Please join forum.mysensors.org for further discussions/help.
[quote=“hirobo, post:1, topic:182739”]Friends,
Please help to solve this problem.[/quote]
I want it to work without vera3.
If vera fails, button still activates the lamps.
If vera fails, button still activates the lamps.[/quote]
Ah now I understand.
I think hek has you all sorted out over @ Mysensors.org
