I have just come home (18.45) and location of my iphone still had not changed since 6.15 this morning. I have Polling period: 720, and Dynamic Polling: map ticked and this 0:900,1:90,5:450,15:900,100:2800 in the field next to it. I guess that there is something wrong ?[/quote]
I have been seeing something peculiar like this and tried to track it down. It seems my Vera Lite was getting loaded and was crashing due to the logs being generated. I seem to have been able to grab the offending logs I believe to help amg0 troubleshoot the problem (as he knows from my PM)
This time my device hasn’t restarted (assuming from a buildup of logs) and I was able to pull live logs. It may require more verbose logs, but I do see something that doesn’t look proper. Down to the offending logs:
08 10/10/13 14:55:40.468 JobHandler_LuaUPnP::HandleActionRequest device: 53 service: urn:micasaverde-com:serviceId:HaDevice1 action: Poll <0x2e2f1680>
08 10/10/13 14:55:40.468 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=53 <0x2e2f1680>
08 10/10/13 14:55:40.468 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HaDevice1 <0x2e2f1680>
08 10/10/13 14:55:40.468 JobHandler_LuaUPnP::HandleActionRequest argument action=Poll <0x2e2f1680>
02 10/10/13 14:55:40.469 Device_LuaUPnP::HandleActionRequest 53 none of the 1 implementations handled it <0x2e2f1680>
02 10/10/13 14:55:40.469 JobHandler_LuaUPnP::RunAction device 53 action urn:micasaverde-com:serviceId:HaDevice1/Poll failed with 501/No implementation <0x2e2f1680>
02 10/10/13 14:55:50.102 ZZZ-POLLING H1,C1,H2,C2,/1/1 <0x2c4f1680>
I’ll add in that DeviceNum 53 is my iPhoneLocator not sure why the name here for serviceId doesn’t reflect as such. Using v1.41 and the polling map is listed as such: 0:60,5:120,10:300,30:900[/quote]
Hello shmixx, no I am sorry but that log does not tell me a lot. . this “Poll” action is probably something internal to Vera and I have no idea what that could be or why this could be failing. The best bet is to enable DEBUG mode like explained and get a complete LuaPNP.log file. you could also run a command like tail -f luaPNP.log | grep iPhoneLocator in a ptty terminal and it will show us exactly all the debug lines generated by the IPhone plugin
NOTE to ALL users: I did pinpoint a potential bug, make sure PollingBase has a numeric value in it , whatever mode you use the polling ( dynamic or not ). no value could cause the plug in to crash and the symptom is no periodic refresh any more
