PLUGIN: Honeywell Total Connect Comfort Thermostats
Conceptually this should work if you can control your devices (stats) via the TCC website. Have you reloaded LUUP ? I know when I first executed the plugin I had to and it short took awhile but the child devices were eventually created.
[quote=“BrewFixer, post:120, topic:185402”]I just installed this app and it installed with no problems. However despite after entering my user name and password and, I have a login success confirmation it tells me “no devices were found”
I have 6 thermostats all visible on the TCC however I am running them through a Honeywell Gateway at Home. My system is 4 zoned all Honeywell equipment. Would this make a difference?[/quote]
Does it work with Honeywell TH9320WF5003?
Link to model: → http://www.alpinehomeair.com/viewproduct.cfm?productID=453067712&linkfrom=froogle&gclid=CjwKEAjwhbCrBRCO7-e7vuXqiT4SJAB2B5u7YKy8endr6QfZsFbHINn016NEGwR8HgnepaaXaAy0IhoCPh7w_wcB
Thanks,
Tommy
[quote=“tommygear@gmail.com, post:122, topic:185402”]Does it work with Honeywell TH9320WF5003?
Thanks,
Tommy[/quote]
The Honeywell website indicates the TH9320 works with the TCC service. Just make sure you have a C wire available to the thermostat to power the WiFi. The plugin should work with that thermostat. I have the RTH9580 and it work great.
Ken
I have a Honeywell WiFI thermostat that can be seen in the Honewell Total Connect Comfort portal online. But whe I add the plugin I get the following error message “HNYWL TCC: : Honeywell TCC Authorization passed, but no devices were found.” Any ideas on why Vera Edge cannot see the thermostat?
Seems today I just noticed that message as well. Running UI5 (last release) on Vera3. Seems the temps are reporting properly (matches that of TCC) so I’ll have to analyze the logs to see what’s going on.
I just noticed the same thing today. I am running firmware version 1.7.619 on a VeraLite. Have same symptoms as CudaNet. Have error message at top of screen but, still able to control my thermostat.
My Vera Edge is now communicating with the thermostat. Not sure if I did anything but I can set temperature if it’s on cool or heat but not auto.
Sent from my SM-G925V using Tapatalk
Same Error. Started 7/15/2015.
Running Firmware: 1.7.619
Plugin Version 1.2
UI 7
ui 5 1.5.672
same error msg.
I did notice the other day on my honeywell app they said they were going to be doing maintenance and the servers would be down over night… i wonder if that had something to do with this?
when i look at TCC setup in the device properties, i says it found my thermostat with the number and everything says successful all over the place. but still that msg… odd
logged into portal. everything looks fine… made changes. they were reflected in vera… made changes in vera, they were reflected back in the portal… so as far as i can tell, this is just a msg, with no meaning… everything works as it should… but why the msg all of a sudden is the mystery.
edit: so having a look at this (and i may be totally wrong) I think honeywell updated LocationList.js on their site to a newer version. and looking at my beta files for this plugin. the function function getDevicesInLocation(locNumber) will need to be modified to correct that.
also some URL’s don’t seem to be valid any longer
local URL_DEVICE_STATUS=“Honeywell Home - My Total Connect Comfort”
local URL_SET_DEVICE_STATUS=“Invalid Action Error”
(again this is from my beta files - he may have changed this stuff in the final)
but someone who is smarter than I can take a look and comment.
I have the same message after a luup restart.
Running firmware:1.7.1248
I too am getting the same error, though operation seems to be working fine. I’d still like to get rid of that error message though :wink:
For those of you who are getting the message but, your thermostat is still connecting to Vera. I do not suggest you uninstall and reinstall the plugin. I tried that and I still get the message at top of screen and there was no thermostat device. I had to manually create the thermostat device and link it back to the parent. I am able to interface with my thermostat once again but, it doesn’t appear to be refreshing properly. I can make change in my VeraLite and they appear on the thermostat. If I make changes on the thermostat they don’t seem to update on the VeraLite for a long time. For instance even though the Thermostat Device indicates the current setpoint is 76, the Advanced Variable for CurrentSetpoint is 0 and for CurrentSetpoint Cool is 75. Once the system cooled the house to 76 the Advanced Variables finally updated. The RefreshInterval on the Parent is set to 300. The RefreshAfterChangeInterval is set to 15. I don’t believe it waited the full 5 minutes to update regardless of which side the change was made before I did the uninstall and reinstall.
I guess mvader is correct, this will take some code modification. Anyone out there able to assist? I believe JoeyD has moved on to other priorities.
I made the mistake of uninstalling/reinstalling to add my newly installed second controller. Ugh, now I can’t access either of the devices.
Bummer, it had been working great!
New to z-wave and Vera… I have a Vera Edge and only have 2 things to setup so far as I am still researching.
Really bummed when I found out that they broke this plugin!
Does anyone have instructions on how to set the thermostat up manually?
Any idea why I am seeing this message
It is finding the thermostat and it is working. so the error message is not true
The message started appearing about a month ago
Seems like everyone is getting the same error now. The plug-in stopped working and the developer who wrote it is no longer active. :frowning:
It really is too bad that this no longer works. I just got my Wifi thermostat and discovered the plug-in does not work. Does anyone know how to add the device manually then? That might help.
Bummer
Does anyone know if Vera will pick it up. They appear to officially support the Nest.
You can try the beta from a while back. Works for me.
http://forum.micasaverde.com/index.php?topic=29938.0
[quote=“guitphreak, post:139, topic:185402”]You can try the beta from a while back. Works for me.
http://forum.micasaverde.com/index.php?topic=29938.0[/quote]
Which set of files did you use? “Alpha”, “Beta1” or “Version 1-0” from that thread?
