PLUGIN: Honeywell Total Connect Comfort Thermostats
I was very excited to see that people were able to get this working. I followed the detailed instructions and it worked!
But… I soon found that having the device set up and working caused my Vera to become unresponsive for long periods of time when it reloaded. I had to take the device out (but left the files in) for now. I am probably the only person left on UI6 LOL I’ll give it another go when I upgrade to UI7. I had issues when I first upgraded and had to roll it back.
don’t graded to UI5 and plugin no longer works. Tried to uninstall and reinstall using the LUUP upload method but device isn’t coming back. Installing through MIOS provided the device and can authenticate but it can’t find my device. Not sure where to put the device ID in within UI5
I have the HONEYWELL TOTAL CONTROL and Vera UI7. It used to work, but today I could no longer control it from the UI. I’ve now re-installed the AP 2X, waiting for it to say it was done.
I tried entering the IP (and tried leaving it blank), entered the credentials. I can see the HTC and control it from the Honeywell website and my phone.
But all it says on the TCC SETUP page is:
Authorization Status:Successful
THERMOSTATS FOUND:
and NONE are listed. I’ve refreshed several times- none appear.
I hit refresh many times and it says RE-initializing devices, then the message vanishes and no devices are present. ???
I dunno what to do I’ve tried everything I can think of…
You need to go back and read this threat from post #140 - forward.
http://forum.micasaverde.com/index.php/topic,30125.msg243786.html#msg243786
thanks Ill try that. I tried the download 6 files manually thread but that failed too… :stuck_out_tongue:
That all went pretty well. #4 was a little dicey:
  1. I typically reload luup at this point for good measure:
    • Devices → The device you just added → Click on “>”, then click on Advanced and scroll to the bottom. Click on “Reload Engine”
SHOULD read (at least in UI7):
    • Devices → The device you just added → Click on “>”, then click on Advanced Tab → Go to NEW SERVICE tab → Click on “Reload Engine”
Thanks Mr JoeyD I finally have the Honeywell back and looking good. ;D
I recently installed this plugin, and having problems with logging into TCC. It keeps giving me Unsuccessful. Error code 200. I’ve verified my credentials, and I don’t have anything hidden like trailing spaces or such. However, it’s notable that my email address used to log into TCC has a plus sign in it. Any chance that’s the problem?
Almost. Running 1.7.1598 Vera Edge.
Installed the beta. Got the parent and child devices, but couldn’t control it. The thermo is id 40 with a parent of 38. Also, “Continuous” fan isn’t showing as a possibility, but that’s what I have my thermostat set at. No controlling of the thermo though.
Read that the plug-in was working, so I tried that next. No luck. Read that I shouldn’t have done that so I uninstalled the plug-in and went to Version 1-0 RC.zip. Still no luck controlling the thermo.
I do have the Honeywell scene created and it is working. My credentials are good, but the thermo doesn’t show actual inside temp and no control. Am I missing something? Are others able to control their units?
[quote=“cohibafan, post:229, topic:185402”]Almost. Running 1.7.1598 Vera Edge.
I do have the Honeywell scene created and it is working. My credentials are good, but the thermo doesn’t show actual inside temp and no control. Am I missing something? Are others able to control their units?[/quote]
I have verified that I can control my units. It sounds like your thermostat ID number(s) are not correct. In the main Honewell app, on the TCC Setup tab, verify that your thermostat ID numbers are correct and that they show a “successful” refresh. If you are unsure what your thermostat ID numbers are, logon to www.mytotalconnectcomfort.com. When you click on a specific thermostat, the 6 digit ID number is shown at the end of the URL.
Are you installing the version of the plugin from the app store or are you downloading and manually installing the older version of the app? The version on the app store does not work. To manually add the older version, you need to go back and read this threat from post #140 - forward. http://forum.micasaverde.com/index.php/topic,30125.msg243786.html#msg243786
Quote from: agflight85 on November 25, 2015, 10:03:19 am I recently installed this plugin, and having problems with logging into TCC. It keeps giving me Unsuccessful. Error code 200. I've verified my credentials, and I don't have anything hidden like trailing spaces or such. However, it's notable that my email address used to log into TCC has a plus sign in it. Any chance that's the problem?
Very similar problem here. I installed the older version of the plugin, but is does not change anything. I don’t have a plus sign in my adress.
The credentials work in this site: https://europe.mytotalconnectcomfort.com/Locations
[quote=“backkri, post:232, topic:185402”]
The credentials work in this site: https://europe.mytotalconnectcomfort.com/Locations[/quote]
I won’t swear to it, but I am pretty sure this plugin only works with the US-based thermostats. https://www.mytotalconnectcomfort.com/portal
That would be my guess too and what I was afraid for, that’s why I mentioned the url… :frowning:
agflight85: Europe or US?
Thanks for the help.
[quote=“backkri, post:234, topic:185402”]That would be my guess too and what I was afraid for, that’s why I mentioned the url… :frowning:
Thanks for the help.[/quote]
You can try using this updated LUA file. The only thing I did was I replaced all of the instances of “https://mytotalconnectcomfort.com/” with “https://europe.mytotalconnectcomfort.com/”. I have no clue if this will work, but it might be worth a try.
Thanks for your help. For the moment, I get GET_LANG(system_error,System error) :device 233: fail to load implementation file L_HoneywellTCC_json.lua
But I have the impression this is an old device. This weekend I have more time, I will clean all old devices / files and try to start from scratch.
I will keep you posted.
It appears that IFTTT has a Honeywell TCC channel. Has anyone tried to use that in tandem with the Connect Maker ? I haven’t had a chance to explore this idea just yet but I did add ‘Connect Maker’ (within IFTTT) and was immediately generated an API key. Everything seems to occur via web hooks and web requests. It maybe worth something or nothing. It just that I do see this plugin (one day) eventually not working at all for various reasons unless another developer takes it over.
Good catch and the Honeywell TCC is new with IFTTT. I know there are some hacks to get Vera to work with IFTTT, but nothing official. If Vera ever gets setup with IFTTT, that would be great. (side note, nearly every other home automation hub has been setup with IFTTT.)
Vera integration would certainly make things easier but I’m trying to only use Vera as a z-wave controller since I’ve moved to openLuup for pretty much everything else. I’ll post back once I’ve had an opportunity to dig into this ‘Connect Maker’.
Good catch and the Honeywell TCC is new with IFTTT. I know there are some hacks to get Vera to work with IFTTT, but nothing official. If Vera ever gets setup with IFTTT, that would be great. (side note, nearly every other home automation hub has been setup with IFTTT.)[/quote]
I have a HoneyWell Thermostat that isn’t wifi but Redlink. I’ve had it for years. I cannot get the plugin to recognize it even though it shows up when I log into the Total Connect network. One thing that I see in several post, it refers to a 6 digit thermostat ID but mine is just a 4 digit one.
