MCV, help!
I’ve had users report that they are trying to install a plugin (CurrentCost) from apps.mios.com and it is putting their Veras into an infinite loop.
I am able to reproduce this.
- Ensure that none of the eleven plugin files is present in /etc/cmh-ludl
- Log in through the Vera interface.
- Go to Apps > Install Apps.
- Find the CurrentCost EnviR plugin in the list.
- Install the plugin, version 25.0
- Wait.
In the Luup log:
[code]08 05/25/12 21:29:13.985 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: CreatePlugin <0x2e54b680>
08 05/25/12 21:29:13.986 JobHandler_LuaUPnP::HandleActionRequest argument PluginNum=1128 <0x2e54b680>
03 05/25/12 21:29:16.297 JobHandler_LuaUPnP::Reload: New Plugin Critical 1 m_bCriticalOnly 0 dirty data 0 <0x2e54b680>
03 05/25/12 21:29:16.297 JobHandler_LuaUPnP::Reload: New Plugin Critical 1 pending write 186, try again later <0x2e54b680>
03 05/25/12 21:29:17.100 JobHandler_LuaUPnP::Reload: PendingWrite Critical 1 m_bCriticalOnly 0 dirty data 0 <0x2c14b680>
06 05/25/12 21:29:17.163 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 v:0xabd7c0/NONE duplicate:0 <0x2c14b680>
06 05/25/12 21:29:17.164 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 v:0xadad28/NONE duplicate:0 <0x2c14b680>
01 05/25/12 21:29:17.282 Mongoose XXX-mg_stop1 0x9f5d80 1 2 <0x2ba18000>
01 05/25/12 21:29:19.283 Mongoose XXX-mg_stop2 0x9f5d80 2 2 <0x2ba18000>
01 05/25/12 21:29:19.283 Mongoose XXX-mg_stop3 0x9f5d80 2 2 <0x2ba18000>
01 05/25/12 21:29:19.284 Mongoose XXX-mg_stop4 0x9f5d80 11427064 2 <0x2ba18000>
2012-05-25 21:29:19 - LuaUPnP Terminated with Exit Code: 250
2012-05-25 21:29:19 - LuaUPnP crash
01 2012-5-25 21:16:22 caught signal 6 <0x2c4d3680>
01 2012-5-25 21:16:38 caught signal 6 <0x2bdcf680>
01 2012-5-25 21:19:0 caught signal 6 <0x2c241680>
01 2012-5-25 21:19:16 caught signal 6 <0x2c475680>
01 2012-5-25 21:19:32 caught signal 6 <0x2c48d680>
01 2012-5-25 21:19:48 caught signal 6 <0x2bb79680>
01 2012-5-25 21:20:4 caught signal 6 <0x2bb5b680>
01 2012-5-25 21:20:56 caught signal 6 <0x2c54b680>
01 2012-5-25 21:29:19 caught signal 6 <0x2c74b680>
---------------exited-------------
[/code]
Afterwards this repeats forever:
[code]03 05/25/12 21:33:36.710 LuaUPNP: starting bLogUPnP 0 <0x2b45a000>
02 05/25/12 21:33:36.719 JobHandler_LuaUPnP::Run: pid 18405 didn’t exit <0x2b45a000>
02 05/25/12 21:33:36.794 UserData::LoadUserData previous: 0 from 1.5.359 <0x2b45a000>
03 05/25/12 21:33:36.812 UserData::LoadUserData BuildVersion: 1.5.359 SvnVersion: 5806 Model: 33 MiCasaVerde VeraLite flush: 0 changed: 0 resync: 10067 syncdevice:1 <0x2b45a000>
02 05/25/12 21:33:36.815 JobHandler_LuaUPnP::FetchMissingFiles need to download plugin 188 <0x2b45a000>
02 05/25/12 21:33:36.816 JobHandler_LuaUPnP::m_sMissingFile_set plugin <0x2b45a000>
01 05/25/12 21:33:36.882 Device_LuaUPnP::LoadDeviceDoc can’t load /etc/cmh-lu//D_CurrentCostEnviR1.xml <0x2b45a000>
02 05/25/12 21:33:36.882 JobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_CurrentCostEnviR1.xml <0x2b45a000>
01 05/25/12 21:33:36.882 JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 186/D_CurrentCostEnviR1.xml so device 186 is offline <0x2b45a000>
01 05/25/12 21:33:37.129 Device_LuaUPnP::CreateServices Aborting device 186 because the topmost device has no interface <0x2b45a000>
01 05/25/12 21:33:37.130 JobHandler_LuaUPnP::CreateAllServices failed to create 186 <0x2b45a000>
01 05/25/12 21:33:37.189 Device_LuaUPnP::CreateImplementations Aborting 186 because it failed to load <0x2b45a000>
01 05/25/12 21:33:37.189 JobHandler_LuaUPnP::CreateAllImplementations failed to create 186 <0x2b45a000>
02 05/25/12 21:33:42.556 JobHandler_LuaUPnP::StartUPnPServices starting with /etc/cmh-ludl/ / http://10.191.21.248:49451/luaupnp.xml <0x2b45a000>
09 05/25/12 21:33:42.661 JobHandler_LuaUPnP::Run device 186 room 0 type urn:schemas-futzle-com:device:CurrentCostEnviR:1 id parent 0/0xa4e380 upnp: 0 <0x2b45a000>
03 05/25/12 21:33:42.680 JobHandler_LuaUPnP::Run ready 24 devices installation 35000308 missing /etc/cmh-lu//D_CurrentCostEnviR1.xml version 1.5.359 allow_evt: 1 allow_ud: 1 upnp 0 changed: 0 pMem 0xc42000 start 10121216 diff: 2732032 <0x2b45a000>
02 05/25/12 21:33:44.101 ZWaveJobHandler::SetDeviceStatus XXX2 0/0/0/0 LEAK this:81920 start:81920 to 0xc56000 <0x2bb8d680>
01 05/25/12 21:33:45.180 JobHandler_LuaUPnP::DownloadPlugin 188 failed to convert error -4: ERROR: no version relased for this plugin LEAK this:-602112 start:73728 to 0xc54000 <0x2bd8d680>
01 05/25/12 21:33:45.181 JobHandler_LuaUPnP::DownloadFiles new plugin 188 returned 0 <0x2bd8d680>
03 05/25/12 21:33:49.133 JobHandler_LuaUPnP::Reload: Downloaded Plugin Critical 0 m_bCriticalOnly 0 dirty data 0 LEAK this:2461696 start:2535424 to 0xead000 <0x2bd8d680>
06 05/25/12 21:33:49.197 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 v:0xb0b7a8/NONE duplicate:0 <0x2bd8d680>
06 05/25/12 21:33:49.198 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 v:0xb28d10/NONE duplicate:0 <0x2bd8d680>
01 05/25/12 21:33:49.323 Mongoose XXX-mg_stop1 0xa422f0 1 2 <0x2b45a000>
01 05/25/12 21:33:51.324 Mongoose XXX-mg_stop2 0xa422f0 2 2 <0x2b45a000>
01 05/25/12 21:33:51.324 Mongoose XXX-mg_stop3 0xa422f0 2 2 <0x2b45a000>
01 05/25/12 21:33:51.325 Mongoose XXX-mg_stop4 0xa422f0 12610752 2 <0x2b45a000>
2012-05-25 21:33:51 - LuaUPnP Terminated with Exit Code: 250
2012-05-25 21:33:51 - LuaUPnP crash
[/code]
This has been reported on 1.5.346 but I also see it on 1.5.359. It’s quite repeatable so you should be able to reproduce it on your test hardware.
Edit: The Plugin 188 stuff is—I think—unrelated. It’s still there after I uninstall the CurrentCost plugin.
