Hi All,
I have a problem with my vera3 and the etherrain 8 plugin. The only fix I have found is a physical power cycle of the vera box. All then is good for 24/48 hours then the plugin fails. Tailing the logs show zero action happening when the failure occurs and the MIOS support team are still on holidays (or might as well be).
Does anyone know if any other plugin (apart from the etherrain 8 plugin) will operate this piece of hardware (irrigation controller).
The controller and support from Jim @ Quicksmart is superb.
Just trying to avoid setting up a separate sprinkler app to control this when the idea of vera is to control everything.
Cheers
