PLUGIN: Caseta Connect
So I just saw in an old post from another thread that cybrmage had a heart attack and was not doing well many months ago. :frowning: I hope he is ok but am guessing he won’t be responding sadly. Just wondering if anyone out there is still using this with a non pro bridge and if it is working for them. I am trying to recreate this but am not getting the same data that he did which makes me wonder if Lutron changed how it works and this broke it. Any info would be great. Thanks!
Nate
This plugin is absolutely spectacular ;D
The only thing that I could possible see to add to this that would be useful is to be able to detect the light dimmer levels when they change (IE: use to detect when the actual Caseta dimmer control is selected to ā€œonā€ or ā€œoffā€ or detect when light level reaches 100%). This would make the one scene that I have run into so far better to program and that is the z-wave switch the controls the light over the sink to come on when the kitchen lights go to 100%. I can see other things as well. Now, if this would cause a serious performance degradation then – no.
Having some trouble with the newest version. I noticed my lutron scenes changed number in vera’s devices after installing, but overall this isn’t a huge issue. However, after running for a little while, I get a Startup Lua Failed notice. I turned on debug and included anything around the word failed that I found in the log around the time that the startup failed notice appeared. I had noticed things would eventually stop working after 2-3 days before, but I had Vera restart daily, and the issues had gone away. But this has been happening frequently since I updated a few days ago. Thoughts?
Edit: I have a Smartbridge Pro 2. Also, the Lutron scenes keep getting removed after every error, and renumbered higher in the vera numbering scheme.
Your log is MISSING huge chunks of time… So, can’t really tell what is going on…
Except, it is specifically showning that it is unable to connect to the bridge… That, along with your statement that it will run for several days, points to the possibility that your router is changing the IP Address of the bridge…
Make sure that you have configured your router to ā€œreserveā€ an IP Address for the smartbridge.
Then, reload the LuaUPnP engine, and if the error happens again, post the logs again… but make sure you go back far enough that you get the plugin startup line ( the one that states ā€œCaseta Connect Automation Gateway v1.63 - ************** STARTING **************ā€)
Sorry about that. Attached is a complete log from start up to failure (only modification was to XXXX out some password stuff for another plugin). The only thing I did to precipitate the failure (within a few minutes) was attempt to add a lutron scene to a vera scene, prompting a LUA startup message in vera, and its subsequent startup LUA failed message. The IP address is manually set to both the vera and the lutron hub on the router (statically at 192.168.2.49 and .53 respectively).
I don’t know if it matters, but there is one switch which is the newer PD-5NE-WH lutron dimmer that I added about 1-2 weeks ago. The rest are the older model dimmers (pro and non-pro), pico remotes, and wall switches.
EDIT: Also, when leaving this alone, it looks like the plugin eventually restarted, but then the lutron scenes never got added back, but individual light control works fine with their original associated vera device numbers still associated with them. I changed the log file attached to include everything, including this later part.
You have MULTIPLE issues…
  1. Your Vera is trying to download the Harmony Hub plugin and is failing to do so. This is forcing the LuaUPnP engine to restart every ~10 minutes.
  2. Your Veras Z-Wave controller is having issues with ā€œdongle is in bad stateā€ and abort errors.
  3. You Lutron Smartbridge is acting in an inconsistent manner.
  4. You Lutron Smartbridge is returning inconsistent data.
Excluding the plugin and Z-Wave issues…
Over the several restarts shown in the logs, the smartbridge failing to respond to the plugin when it tries to connect to the LIP server, causing the plugin show as failed. This is NOT the plugin failing, this is the bridge failing to allow a connection, which prevents the plugin from operating.
The few times that the bridge does allow a connection to the LIP server, the plugin appears to be operating as intended.
The other issue is that the smartbridge is reporting various configuration sections inconsistently… This is causing the plugin to create the devices for the Lutron scenes, which requires a restart… the bridge then fails to report the scenes, causing the plugin to delete the devices for the Lutron scenes, which requires a restart… which becomes a restart loop until the same data is reported in two consecutive restarts… which then allows the plugin to operate normally… Until the plugin issue forces a restart…
You need to get BOTH your Vera and your Lutron smartbridge into a consistent state…
First step is to unplug BOTH the Vera and the Smartbridge and allow them to remain off for several minutes… then plug them in, and retest…
Wow, that bad, huh…
I greatly appreciate your help trying to narrow down the many issues on my device, especially since it appears unrelated to your plugin specifically. I had tried rebooting both devices in my attempts at fixing things, but not for a sustained period of time for more than 5 min or so. I went ahead and did as you asked, unplugging both for 15 minutes and replugging in. Prior to that, I had deleted the Harmony Hub plugin, as my use for it on vera was minimal.
Thus far, even when changing scene information requiring a reloading of the Lua plugins, it appears everything works correctly. I haven’t yet received an error with the plugin loading, and the lutron scenes have a new, but more importantly, stable, number that hasn’t yet changed. They persisted after a restart as well, so things are looking promising.
We’ll see how everything goes for a few days, and I’ll report back if the issues return, but at least in my 30 minutes of testing, things are MUCH more stable than they were prior to your help. I don’t know what is going on with the Z-wave devices, but at least from a usability point of view, they’re still working well. Thanks again for the troubleshooting, and for making such an amazing plugin!
The ā€œfailed plugin downloadā€ is one of the hardest problems to find unless you look at the verbose logs… and it has a HUGE impact on the systems usability… A restart every 10 minutes for no obvious reason is definately a big reliability killer.
That indicates that everything is good… The Smartbridge has a tendancy to go wonky if you add/remove a lot of devices/scenes at once or if the bridge is near its device limit… My recommendation… If you add/remove devices/scenes on the smartbridge, power cycle the smartbridege before you reload the LuaUPnP engine to sync the new configuration.
The Z-Wave issues could be a simple matter of the Z-Wave dongle (built into the Vera) having a hard time coping with interference, or acting wonky dur to a power surge… or Vera not able to talk to it due to memory issues… The abort errors MAY indicate that you have a device that Vera is having trouble communicating with… It could be too far away, or in a location where the signal is obstructed or it could be a failing or marginal device. As long as your Vera is able to control and communicate with the Z-Wave devices without a significant delay, it’s usually not something to be overly concerned with.
I’m glad things are running smoother for you now…
Hello! Great work on the plugins. I’m new to the forums and to Vera in general, but I think perhaps I found a bug in the Caseta plugin.
I have a non-pro Smart Bridge. When switch the lights on/off from the wall panel or the PICO, I would expect the Vera dashboard/panel to update showing the change. I’ve waited a number of minutes and it doesn’t refresh. However, if I restart the Vera Lite, then it grabs the correct percentage and on/off status.
Looking at the logs I notice the following in red (in bold):
01 02/05/17 21:35:09.476 IOPort::Connect connect -1 lutron.broker.xively.com:1883 <0x2d789680>
50 02/05/17 21:35:46.106 luup_log:11: MQTT.client:handler(): PINGREQ <0x2c389680>
01 02/05/17 21:36:16.059 LuaInterface::CallFunction_Timer device 11 MQTT_KeepAlive took 30 seconds <0x2c389680>
When I check port 1883 on lutron.broker.xively.com, it fails, but port 8883 connects. (I found port 8883 while sniffing traffic from my iPhone Lutron app.)
$ telnet lutron.broker.xively.com 8883 Trying 52.23.255.236... Connected to lutron.broker.xively.com.
I’m not sure what the ā€œconnect -1ā€ part of the above log means, but does it mean that it cannot connect? Might the port have changed to 8883? Is there a way to change that port number and try it?
Many thanks!
Hello,
I picked up a Pro2 bridge and it’s working well. I’m having a couple of issues with 2 of my three remotes not sending certain commands Scene back to Vera.
I’ve tried replacing the remote batteries. Is there an easy way to debug this to see what’s happening?
I would like to see if the plugin is seeing the button presses as expected.
Please let me know next steps.
UPDATE - Remote seems to be working fine. It just won’t trigger 2 of 6 scenes…?
What could be causing the system to trigger some but not all scenes?
In my example, I have an IR blaster connected to VERA over IP that controls my TV.
Vol+ / Vol - / Mute Work but TV On / TV Off don’t work.
All of these scene’s work perfectly when I trigger them via the Vera app or vera web gui.
Is there a naming / character limitation in the Scene names? I have a one other Pico remote that works perfectly for another room and when I sawp them I get the same result.
Note sure where to go to start troubleshooting. I have logging enabled on Vera - Would the log explain what’s happening?
Any help would be greatly appreciated.
Would it be possible to update the subcategory of the device that gets created for the Caseta On/Off switch (PD-5WS-DV-WH)? Right now they are getting created with subcategory 0 which causes them to not be included in the lights for the Turn All On/Turn All Off shortcut. Manually changing them to subcategory 1 (Interior) works.
Could someone please provide me with the proper Luup code to activate a Caseta Scene via the Caseta Connect plugin?? I would like to use luup to check the status of a light sensor, run one Caseta scene if the sensor is above 15 lux, and run a different Caseta scene if the sensor is below 15 lux. For the life of me I can’t figure out the correct syntax (I am new at this).
I’ve tried:
(because Caseta scenes show as SwitchPower1 in the device log)
local dark_scene = 73 luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{newTargetValue="1"},dark_scene)
(because I’m trying to run a scene)
local dark_scene = 73 luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1","RunScene",{ SceneNum=dark_scene },0)
(because I’m trying to run a Caseta scene)
local dark_scene = 73 luup.call_action("urn:caseta-com:serviceId:CasetaScene1","RunScene",{SceneNum=dark_scene},0)
No luck… help please!
Relaying back some information since I last posted about scenes being renumbered and all sorts of vera problems. Well, I still was having some issues (although better than before), so I fully reset the Vera and the Lutron smartbridge, and readded every device.
Things seem maybe slightly better, but I was still having issues with the smartbridge not communicating with the plugin after about 3-4 days, but it seemed that the telnet part of the Lutron smartbridge stopped communicating. Putting the Lutron hub on a timer to reboot itself daily appeared to fix most of the issues with the exception of one.
I still occasionally have problems with the lutron scenes renumbering themselves in the Vera, which messes with my vera scenes. I haven’t added or removed anything from the smartbridge or vera, yet this appears to occur on a weekly basis roughly. I don’t know if this is because I have 48 Lutron devices, since as you mentioned, the hub appears to go a bit wonky as you near the 50 device limit.
As a work around, I stopped using Lutron scenes in any of the vera scenes, but could there be an option placed to disable the plugin from loading vera scenes, just so they’re not recreated randomly? Thanks!
Any clue as of why altui complains about mdns_devices function in openluup?
stack:TypeError: mdns_devices.split is not a function
    at selectBridgeDevice (:86:36)
    at eval (eval at _deviceDrawControlPanelJSTab (http://xxx.xxx.xxx.xxx:3480/J_ALTUI_uimgr.js:2893:17), :1:1)
    at _deviceDrawControlPanelOneTabContent (http://xxx.xxx.xxx.xxx:3480/J_ALTUI_uimgr.js:3413:8)
    at _displayActiveDeviceTab (http://xxx.xxx.xxx.xxx:3480/J_ALTUI_uimgr.js:3440:4)
    at HTMLAnchorElement. (http://xxx.xxx.xxx.xxx:3480/J_ALTUI_uimgr.js:6348:4)
    at HTMLDivElement.dispatch (http://xxx.xxx.xxx.xxx:3480/icons/localCDN/jquery.min.js:3:7537)
    at HTMLDivElement.r.handle (http://xxx.xxx.xxx.xxx:3480/icons/localCDN/jquery.min.js:3:5620)
    at Object.trigger (http://xxx.xxx.xxx.xxx:3480/icons/localCDN/jquery.min.js:4:4818)
    at HTMLAnchorElement. (http://xxx.xxx.xxx.xxx:3480/icons/localCDN/jquery.min.js:4:5328)
It also complains here:
2017-06-25 14:49:14.396   openLuup.context_switch::  ERROR: [string "[231] I_CasetaConnect.xml"]:1392: attempt to perform arithmetic on global 'init_year' (a nil value)stack traceback:
	./openLuup/scheduler.lua:128: in function <./openLuup/scheduler.lua:125>
	(tail call): ?
	./openLuup/scheduler.lua:238: in function 'dispatch'
	./openLuup/scheduler.lua:705: in function 'task_callbacks'
	./openLuup/scheduler.lua:1084: in function 'start'
	openLuup/init.lua:322: in main chunk
	[C]: ?
Found a little bug…
The app is trying to read the openluup version as ā€œrevisionDateā€ but it is defined as ā€œVERSIONā€ . after modifying ā€œL_CasetaConnect.luaā€ line 1390 from:
                        INITversion = self:shellExecute('head -n 3 /etc/cmh-ludl/openLuup/init.lua |grep -e "revisionDate ="')
to this:
                        INITversion = self:shellExecute('head -n 3 /etc/cmh-ludl/openLuup/init.lua |grep -e "VERSION "')
and this:
                        IOversion = self:shellExecute('head -n 3 /etc/cmh-ludl/openLuup/io.lua |grep -e "revisionDate ="')
to this:
                        IOversion = self:shellExecute('head -n 3 /etc/cmh-ludl/openLuup/io.lua |grep -e "VERSION "')
everything started working…
Hello,
I have a Vera Plus UI7 with the Caseta Connect 1.63 plugin with no other devices configured.
I am unable to have the plugin discover my Caseta Pro hub.
Please see the log entry below.
Thank you!
02 08/10/17 21:51:56.128 luup_log:6: (Caseta_Connect::Caseta_Startup): Caseta Connect Automation Gateway v1.63 - ************** STARTING ************** <0x773e8520>
06 08/10/17 21:51:56.128 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: BRIDGE_STATUS was: Retrieving Bridge Config… now: Loading Options… #hooks: 0 upnp: 0 skip: 0 v:0xeb3fd0/NONE duplicate:0 <0x773e8520>
02 08/10/17 21:51:56.129 luup_log:6: (Caseta_Connect::getMiosVersion): MIOS_VERSION [UI7]. <0x773e8520>
50 08/10/17 21:51:56.129 luup_log:6: (Caseta_Connect::Caseta_Startup): Caseta Smart Bridge Connect Gateway - Plugin version [1.63] - isDisabled [0] MIOS_VERSION [UI7] <0x773e8520>
06 08/10/17 21:51:56.129 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: BRIDGE_STATUS was: Loading Options… now: Validating… #hooks: 0 upnp: 0 skip: 0 v:0xeb3fd0/NONE duplicate:0 <0x773e8520>
06 08/10/17 21:51:56.265 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: MISMATCHED_FILES was: NONE now: NONE #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x773e8520>
06 08/10/17 21:51:56.266 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: BRIDGE_STATUS was: Validating… now: Loading Options… #hooks: 0 upnp: 0 skip: 0 v:0xeb3fd0/NONE duplicate:0 <0x773e8520>
06 08/10/17 21:51:56.266 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: UI7Check was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x773e8520>
06 08/10/17 21:51:56.267 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: BRIDGE_STATUS was: Loading Options… now: Creating Icons… #hooks: 0 upnp: 0 skip: 0 v:0xeb3fd0/NONE duplicate:0 <0x773e8520>
02 08/10/17 21:51:56.268 luup_log:6: (Caseta_Connect::findBridge): Attempting to find Caseta Smart Bridge… <0x773e8520>
06 08/10/17 21:51:56.268 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: BRIDGE_STATUS was: Creating Icons… now: Finding Bridge… #hooks: 0 upnp: 0 skip: 0 v:0xeb3fd0/NONE duplicate:0 <0x773e8520>
02 08/10/17 21:51:56.269 luup_log:6: (Caseta_Connect::findBridge): Using previously configured Caseta Smart Bridge… <0x773e8520>
50 08/10/17 21:51:56.269 luup_log:6: Caseta_Connect::CASETA::configureBridgeConnection: Preparing Caseta Integration support elements. <0x773e8520>
50 08/10/17 21:51:56.270 luup_log:6: Caseta_Connect::CASETA::configureBridgeConnection: Using existing keyfile. <0x773e8520>
50 08/10/17 21:51:56.270 luup_log:6: Caseta_Connect::CASETA::configureBridgeConnection: Using existing socat executable. <0x773e8520>
06 08/10/17 21:51:56.270 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:CasetaConnect1 variable: BRIDGE_STATUS was: Finding Bridge… now: Retrieving Bridge Config… #hooks: 0 upnp: 0 skip: 0 v:0xeb3fd0/NONE duplicate:0 <0x773e8520>
^C
root@MiOS_50011868:/tmp/log/cmh# tail -f LuaUPnP.log
02 08/10/17 21:52:26.207 luup_log:6: (Caseta_Connect::Startup): getBridgeConfig returned 6 entries. <0x773e8520>
50 08/10/17 21:52:26.261 luup_log:6: (Caseta_Connect::CASETA::processBridgeConfig): Processing Smart Bridge configuration. <0x773e8520>
50 08/10/17 21:52:26.262 luup_log:6: (Caseta_Connect::CASETA::processBridgeConfig): Found SERVER - type [LEAP] EnableState [Enabled] JSON [{ā€œEnableStateā€: ā€œEnabledā€,ā€œTypeā€: ā€œLEAPā€,ā€œhrefā€: ā€œ/server/1ā€,ā€œNetworkInterfacesā€: {{ā€œhrefā€: ā€œ/networkinterface/1ā€}}}] <0x773e8520>
50 08/10/17 21:52:26.263 luup_log:6: (Caseta_Connect::CASETA::processBridgeConfig): Found SERVER - type [LIP] EnableState [Enabled] JSON [{ā€œTypeā€: ā€œLIPā€,ā€œLIPPropertiesā€: {ā€œIdsā€: {ā€œhrefā€: ā€œ/server/2/idā€}},ā€œNetworkInterfacesā€: {{ā€œhrefā€: ā€œ/networkinterface/1ā€}},ā€œhrefā€: ā€œ/server/2ā€,ā€œEnableStateā€: ā€œEnabledā€}] <0x773e8520>
01 08/10/17 21:52:26.264 LuaInterface::CallFunction_Startup device 6 function Caseta_Startup took 30 seconds <0x773e8520>
01 08/10/17 21:52:26.264 LuaInterface::CallFunction_Startup-1 device 6 function Caseta_Startup failed [string ā€œā€“Caseta_Connect v1.63ā€¦ā€]:1971: attempt to index field ā€˜Buttons’ (a nil value) <0x773e8520>
01 08/10/17 21:52:26.264 LuImplementation::StartLua running startup code for 6 I_CasetaConnect.xml failed <0x773e8520>
I am running UI17 with 1.73015. Everything was great running the Caseta app on version 1.63. Now that 1.65 has automatically updated I get the error ā€œFailed to load bridge configā€ Running the Pro Bridge
Any suggestions?
new version
v1.75 (Version ID: 34472) September 12, 2017
– added - LEAP service monitor to provide real-time status updates to smartbridge (non-pro) in place of MQTT
– changed - removed obsolete embedded MQTT client (Lutron move the MQTT data to a secure server - The Vera IO model is not compatible with the requirements for TLS encapsulation)
** NOTE ** - The Lutron account credentials that were required to use MQTT are no longer required. There credentials are now only used for bridge discovery.
Back up and running. Thank you !
1.75 keeps dropping connection between vera and pro bridge. I have turned off auto update and restored to 1.65 to keep working. Any idea why 1.75 caused this? i’m using vera pro UI17 with 1.73015.
