Since updating to 4.4 I’ve had a problem where changes ONLY to Message Overrides revert back to previous settings, randomly. I make changes and they stay, and work, fine for a few hours - then “magically” the settings revert back the the exact same setting it was before the changes.
Running the reports before and after confirm they are different.
No other plugin or even part of the Vera Alerts plug has this issue. I changed other items (virtual devices, automation, etc) and they ‘stick’ just fine while all changed Message Override revert back to previous state. I suspect they are not properly being written to memory.
I use Firefox as my browser but I’m now testing with IE10 to see if I get the same problem
I will report back tomorrow morning at the latest to let you know if they stay or revert.
OK. Did it again… this morning I woke up and loading the dashboard into Firefox… all settings were back to what they were at 8pm last night.
AND, to boot, last night after I made the changed usign IE10, I did a backup using IE10… restoring that backup this morning DID NOT put hte settings correctly - it has the old/incorrect settings.
So I can only conclude right now that browser was not the problem… settings for Message Overrides are ONLY working while in memory but not saving to NVRAM.
Richard,
This is definitely not Browser specific… this is a bug. See the bottom for my last browser test.
I also noticed that none of the settings, except Profiles, are accessible from the Advanced tab?
I wanted to backup/restore using those settings but it is not possible???
and then uninstalling if that does not work. Can you post 4.3 in case I need it?
Attached is the log in Chrome of the SAVE.
Since Chrome but it does not allow me to save the REPORT as HTM (WTF?) I had to re-do everything in FF and save, I attached both Before & After reports.
Latest Test:
Also, an interesting note… I rebooted and had not used the PC for about an hour then I came home to do the this for you.
I opened Chrome to the Vera page… and had not yet opened FF
I made the changes, saved it in Chrome and could see all the changes after Vera repopulated the web page.
BUT then I opened FF and navigated to Vera… the changes did not stick and it was showing the old settings.
I went back to Chrome, refreshed, and BOOM… no more new settings, only the old settings.
I redid everything again in FF
Saved
even did another RELOAD
all the settings were still there UNTIL… I did CTRL-F5, boom all gone, back to the old settings.
I need the Vera Debug log file not the Browser log file.
Turn debug on in the Settings tab. Then capture the Vera Log during a Reload where you change msg over-rides and then do a save.
I changed like 5 overrides. Oddly enough, I did notice each time I’ve tested, no matter how many I change, your text message at the top of teh VeraAlert window says ‘1 notification has been changed’.
thx for helping - I love Vera Alerts… my wife hates it, sometimes
I just opened after a browser crash, it has reverted again. This itime I noticed this at the top of the Vera Alerts box…
“You must open this tab after you Add, Modify, and/or Delete any Device or Trigger Notifications in Vera; followed by a save!
12 Device Notifications were updated.”
And Vera’s red SAVE button is showing… even though I have made zero changes.
There is a BUG in MCV software for REMOTE updates.
This should work if you make your message overrides locally.
Similarly there is a problem creating/modifying profiles remotely.
[quote=“RichardTSchaefer, post:12, topic:178400”]There is a BUG in MCV software for REMOTE updates.
Similarly there is a problem creating/modifying profiles remotely.[/quote]
The BUG is definitely also LOCAL with VeraAlerts - this problem did not happen on previous VeraAlerts versions. I suspect there is still a bug somewhere in VeraAlerts.
I just tested again using FF & Chrome connecting directly to my internal IP (192.168.2.xx) sitting at my desktop which is on the same Gig switch as the Vera (this has always been the case)
… F5 refresh kills any updates I make.
One interesting finding (not 100% verified but I added 11 new ones that stuck a week ago)… seem that ‘new’ notifications, ones that have NEVER been in VA before, stick BUT any existing notifications cannot be updated/changed.
I know I’ve asked before, but this is a perfect example of the need for Import/Export feature. At least if a bug wipes/screws up the config we can import it back in with ease once the bugs are fixed. As it stands now, I may need to manually update 50+ notifications which most look like this…
FRONT DOOR Lock{device([172].service[urn:upnp-org:serviceId:VSwitch1].Status) | Choose(0={tone:3},1={tone:1})}
and even copy/paste is a PITA.
